flashback
reacted to
airshot's post
in the thread
Which kicker mount to install?
with
Like
While not easy, some how you need to access the underside of that flat surface as that would be the easiest area to attach a mount. One...
Apr 12, 2026
redneck joe
replied to the thread
2026 NFL/CFB News and Nonsense
A team leader is not washed, sports or business and I'll put money on the 500 mark.
Apr 12, 2026
redneck joe
Is the kicker for trolling or ba k up poswer?
Apr 12, 2026
redneck joe
reacted to
FLATHEAD's post
in the thread
old pictures
with
Like
Cousin sent me this. I’m guessing 1965 or 1966. I’m the kid second from left. The others are my sisters , cousins and Aunt.
Apr 12, 2026
T
tphoyt
reacted to
DeepCMark58A's post
in the thread
Been a little cold.
with
Like
The snowman that was made on Easter fell over, I believe we are snow free, the lake opened up yesterday. It smells like spring outside.
Apr 12, 2026
reacted to
alldodge's post
in the thread
Metal O-Ring appeared on alignment tool
with
Like
That's the inner spine on a lip type seal. Probably from the grease seal behind the gimbal bearing Edit Bondo was quicker
Apr 12, 2026
reacted to
Lou C's post
in the thread
why is there oil in my bellows but pressure test holds 15psi overnight
with
Like
Smell what you found there. Because if you have a grease-able gimble bearing sometimes the grease will separate out in a runny...
Apr 12, 2026
Apr 12, 2026
Fun Times
Does This Sound Right? Bravo Install
No, doesn't sound right... maybe try pulling the drive off and see if the noise goes away/changes....But be sure to add water to the...
Apr 12, 2026
Ayuh,........ That is the tension spring from the gimbel bearing seal,.....
Apr 12, 2026
G
gmach
95 Sea Ray 230 Sundancer stringer repair
Well, I've decided to use thickened epoxy to bed the transom. The bad part is, I will have to baby sit the job with a rag and acetone to...
Apr 12, 2026
FLATHEAD
old pictures
Apr 12, 2026
No dipstick on 1989 era 3.0L?
Why overthink it? The 3.0 has had SAE 30 weight, 10W-30, 10W-40, and 20w-50 recommended in publications from Mercruiser, Volvo Penta...
Apr 12, 2026
reacted to
Fun Times's post
in the thread
Can't change password
with
Like
Hi there, well unfortunately we have discovered that the websites internal inbound and outbound email system are inoperative in-turn...
Apr 12, 2026
Fun Times
reacted to
Lou C's post
in the thread
with
Like
Apr 12, 2026
