J
Jeff J
replied to the thread
Paintball gun
Bruises the size of quarters and half-dollars all over the torso and arms. Ours were required to be tested not to exceed 300 fps. No...
Apr 12, 2026
JimS123
Boat Cover Repair?
Just understand that if you intend to drive the boat on the highway, some of these approaches may not last long.
Apr 12, 2026
J
Jeff J
Ideas for planters/raised beds?
We are using tubs that cattle feed comes in (might be mineral tubs). We got some several years ago for free from a guy who had some...
Apr 12, 2026
rolmops
reacted to
racerone's post
in the thread
Which kicker mount to install?
with
Like
I doubt that anyone needs to invest $10,000 so they can go slow.
Apr 12, 2026
Fun Times
reacted to
nola mike's post
in the thread
Throttle cable replacement...
with
Like
Have had a sticking throttle cable that got annoyingly bad last season. Had a spare box/cable from the old donor boat. I pulled the...
Apr 12, 2026
reacted to
nola mike's post
in the thread
with
Like
Apr 12, 2026
Kola16
reacted to
Fun Times's post
in the thread
Does This Sound Right? Bravo Install
with
Like
No, doesn't sound right... maybe try pulling the drive off and see if the noise goes away/changes....But be sure to add water to the...
Apr 12, 2026
nola mike
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
Apr 12, 2026
S
Shawnspeed
StarCraft 181 SS conversion
So , it’s been a minute… and I’ve abandoned the Tube Transom, and went back to a marine grade plywood transom, the added cost of the...
Apr 12, 2026
T
tphoyt
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
I cleaned-up some of the wiring in the (former) engine bay in preparation for some grinding and glassing. . . I put a few 1/2" spacers...
Apr 12, 2026
nola mike
Almost there
So went back to the boat after a couple of weeks. Fluid level normal. There has been some oil in the bilge since I pulled the engine...
Apr 12, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
Apr 12, 2026
tpenfield
Apr 12, 2026
redneck joe
Wood will be gone to sh.t is a couple years. Fiberglass tubs are your answer. Got a dremel and a kid/grandkids? Make the base an...
Apr 12, 2026
P
Pmt133
reacted to
gmach's post
in the thread
95 Sea Ray 230 Sundancer stringer repair
with
Like
Well, I've decided to use thickened epoxy to bed the transom. The bad part is, I will have to baby sit the job with a rag and acetone to...
Apr 12, 2026
