roscoe
replied to the thread
StarCraft 181 SS conversion
If I remember correctly, the splash well on my 18SS and my 70's mariner, was 34" front to transom. I then bought a newer Mariner ('82)...
Apr 12, 2026
6
68glasspar
No spark 55 HP Evinrude triumph 1969
I went thru this very problem with my 1969 85hp evinrude last year! The info that Crosbyman gave you is top notch. Use it to get you to...
Apr 12, 2026
roscoe
reacted to
KXP's post
in the thread
89 force tilt and trim valve body
with
Like
I went ahead and put the old o ring and the gasket and it worked it stayed up didn’t drop at all. Thanks
Apr 12, 2026
6
68glasspar
reacted to
racerone's post
in the thread
with
Like
????---You have to pull the flywheel.-----Check breaker point gap.----Clean rotor and distributor cap.---Check anti-reversing spring.
Apr 12, 2026
Grub54891
reacted to
FLATHEAD's post
in the thread
Trail camera issues fixed, now pics from them ...
with
Like
He got another grey squirrel. This fox is a good hunter. 😎
Apr 12, 2026
Grub54891
reacted to
Kwanza's post
in the thread
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
with
Like
An update on the above issue. I will probably wait until I can take the boat to the mechanic, as I am afraid of doing further...
Apr 12, 2026
Grub54891
reacted to
MarineSp's post
in the thread
with
Like
Good news is the alternator itself is fine since it charges at 14V once backfed. Alldodge is right about peeling back that insulation —...
Apr 12, 2026
Grub54891
reacted to
redneck joe's post
in the thread
Random
with
Like
https://www.facebook.com/share/r/1B7dVRQk7T/
Apr 12, 2026
WIMUSKY
reacted to
tphoyt's post
in the thread
with
Like
A happy little squirrel
Apr 12, 2026
WIMUSKY
Just thought I'd share a nice photo.
Haven't had them yet, but I hear they're fantastic. Alot of fisherman are targeting them....
Apr 12, 2026
K
KXP
Apr 12, 2026
S
Shawnspeed
I bought 3/4 marine plywood, and laminated 2 pieces together and sealed with polyester resin… and the splash well depth/length must be...
Apr 12, 2026
J
JasonB
reacted to
Chris1956's post
in the thread
Stripped drain plug
with
Like
Garboard drain fittings are avail. A couple of thru bolts and some silicone could install it.
Apr 12, 2026
reacted to
muc's post
in the thread
Merc 250 Verado Fuel increase
with
Like
Next time you have techmate out on the water, look for Demand Linear - Demand - Demand with Guardian. All 3 of these should be at or...
Apr 12, 2026
rolmops
It depends on the engine that you hang on there. By this, I mean how far forward the engine comes over the transom when it is down and...
Apr 12, 2026
