replied to the thread
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
A fully charged resting Bat should read 12.7V that is after it has sat for an hour or so off the charger. Once motor has reved above...
Apr 14, 2026
J
Jeff J
Ideas for planters/raised beds?
Not everyone has dirt suitable for farming. Getting up and down, if able, also helps a person stay active and limber.
Apr 14, 2026
R
No spark 55 HP Evinrude triumph 1969
Do you have spark out of the coil?
Apr 14, 2026
D
DeepCMark58A
reacted to
Scott Danforth's post
in the thread
Paintball gun
with
Like
It's not the dogs fault it's out wandering
Apr 14, 2026
2000 Cruisers 2870 Check Engine light blinking but no codes?
Should be an MEFI ECM. you have to jump the pins to put it in diagnostic mode and read the flashes. you will need to get the VP MEFI...
Apr 14, 2026
CLi87
Just made it out to the boat, so I tested the oil pressure sensor, temp sensor and drive lube sensor by unplugging then to see if any...
Apr 14, 2026
Metal O-Ring appeared on alignment tool
thats a pull the gimbal bearing thing now. once the garter springs come off, you cant get them to stay on.
Apr 14, 2026
reacted to
Bondo's post
in the thread
with
Like
Ayuh,........ That is the tension spring from the gimbel bearing seal,.....
Apr 14, 2026
D
dypcdiver
I believe they call it a garter spring on the oil seal.
Apr 14, 2026
jimmbo
It is 57 yrs old. A lot of Gremlins take up Residence in old Electronics
Apr 14, 2026
roscoe
What is the benefit of a raised garden if you still have to bend over and reach down below your knees? Or actually get on your knees...
Apr 14, 2026
FLATHEAD
Paintball gun
The owners are at fault for dogs running at large. Not the dog. I would never shoot a dog just for being a dog with the exception of...
Apr 14, 2026
K
Kwanza
Should read flinches slightly at the trim, 0.5 V, but comes back.
Apr 14, 2026
redneck joe
Nobody fishing?
Just a day?
Apr 14, 2026
redneck joe
reacted to
Mc Tool's post
in the thread
Nobody fishing?
with
Like
For those of you that tie the FG knot .....I find the final tying off all half hitches a fiddle ,what I have just pioneered is to suss...
Apr 14, 2026
