S
saltchuckmatt
replied to the thread
Motor lift plate
They look a little scary but I've never had a problem with mine. 25 inch 115 E-tec on a 20 inch transom. The good thing is, it tilts way...
Apr 14, 2026
C
Chuck4741444
Motor lift plate
They say they will hold 225
Apr 14, 2026
A
AusFox
Mercruiser 350 MAG MPI
Testing in good conditions shows we are getting 4800 RPM. The owner said we are still about 2-3 knots (GPS tested) speed off what he has...
Apr 14, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Good question and I am glad you asked . . . I can answer that with a series of drawings that track the forces created by the engines...
Apr 14, 2026
M
Mc Tool
Nobody fishing?
You blimmin jinx 😆😁 Had a repeat today Managed to save this one then got this which turned into this and this these cheeky buggers...
Apr 14, 2026
B
boscoe99
reacted to
99yam40's post
in the thread
Suzuki df200ap 2021 outboard thermostat
with
Like
is that with motor running to get the stat open and fresh water circulating thru the open stat?
Apr 14, 2026
B
boscoe99
"OEM thermostat was corroded and rotted out after 60 hours of use" We love the prices of cheap stuff no matter where it comes from...
Apr 14, 2026
K
Kwanza
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
Apologies, my actual numbers are closer to the ones you mention, yes. Resting battery - it has taken a battering after all the trials...
Apr 14, 2026
K
Kwanza
reacted to
alldodge's post
in the thread
with
Like
A fully charged resting Bat should read 12.7V that is after it has sat for an hour or so off the charger. Once motor has reved above...
Apr 14, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
A day of cutting and grinding . . . . I got a lot of the transom reinforcement structure cut . . . still a few more pieces to go. . ...
Apr 14, 2026
P
pae0332
4.3 throttle dependent squeal - not belt related
good job, i pulled a completely rebuilt engine out of a boat cause i thought it was coming from the balance shaft bearing. its the only...
Apr 14, 2026
P
pae0332
why is there oil in my bellows but pressure test holds 15psi overnight
sealed bearing, no grease on bravos
Apr 14, 2026
S
saltchuckmatt
Motor lift plate
I've had, have two on my 115's I believe you order them based on your HP. I could be wrong
Apr 14, 2026
dwco5051
posted the thread
Is this considered as an outboard or !/O powered?
in
Dockside Chat
https://www.facebook.com/reel/1348914633728645
Apr 14, 2026
A
airshot
My carb is obsolete.. Please help me repair/replace!
In my opinion, nothing beats a good factory rebuild kit, thoroughly cleaned carb and reset to factory specs. Always worked well for me...
Apr 14, 2026
