redneck joe
replied to the thread
Random
My apologies for this one.... https://www.facebook.com/share/r/1AqQP8TqTC/
Apr 15, 2026
FLATHEAD
reacted to
Mc Tool's post
in the thread
Nobody fishing?
with
Like
You blimmin jinx 😆😁 Had a repeat today Managed to save this one then got this which turned into this and this these cheeky buggers...
Apr 15, 2026
tpenfield
I/O (Sterndrive) Conversion to Outboards
Here is the difference in those 2 boats (Formula 310 I/O vs OB) The outboard version has the hull extended at the full height of the...
Apr 15, 2026
R
retroroy
1990 vs 1996 9.9hp 4 stroke cylinder head/ gasket interchange?
I figured I'd follow up on this. I was able to use the Mariner head on the Yamaha motor, although the two are different displacements...
Apr 15, 2026
redneck joe
Random
https://www.facebook.com/share/r/1CASCAZFY3/
Apr 15, 2026
redneck joe
reacted to
Mc Tool's post
in the thread
Nobody fishing?
with
Like
Apr 15, 2026
S
saltchuckmatt
Motor lift plate
They look a little scary but I've never had a problem with mine. 25 inch 115 E-tec on a 20 inch transom. The good thing is, it tilts way...
Apr 14, 2026
C
Chuck4741444
Motor lift plate
They say they will hold 225
Apr 14, 2026
A
AusFox
Mercruiser 350 MAG MPI
Testing in good conditions shows we are getting 4800 RPM. The owner said we are still about 2-3 knots (GPS tested) speed off what he has...
Apr 14, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
with
Like
Good question and I am glad you asked . . . I can answer that with a series of drawings that track the forces created by the engines...
Apr 14, 2026
M
Mc Tool
Nobody fishing?
Apr 14, 2026
B
boscoe99
reacted to
99yam40's post
in the thread
Suzuki df200ap 2021 outboard thermostat
with
Like
is that with motor running to get the stat open and fresh water circulating thru the open stat?
Apr 14, 2026
B
boscoe99
"OEM thermostat was corroded and rotted out after 60 hours of use" We love the prices of cheap stuff no matter where it comes from...
Apr 14, 2026
K
Kwanza
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
Apologies, my actual numbers are closer to the ones you mention, yes. Resting battery - it has taken a battering after all the trials...
Apr 14, 2026
K
Kwanza
reacted to
alldodge's post
in the thread
with
Like
A fully charged resting Bat should read 12.7V that is after it has sat for an hour or so off the charger. Once motor has reved above...
Apr 14, 2026
