replied to the thread
Alpha One Gen II Lower Unit - Drive Shaft Binds When Tightening Retainer
I'm having trouble following your comments, maybe it's the terms This is talking lower You pulled the lower apart but did not...
Apr 15, 2026
S
SlipperyOar
1981 Springbok 18' Restoration/Renovation
Got some side panels made up today. Needed something to cover up the sides of the hull and also give me a spot to mount my motor...
Apr 15, 2026
flashback
reacted to
Scott Danforth's post
in the thread
Pushing Run-Flat tires to the limit
with
Like
AAA is an opt-in for most towing companies. they only get $35 per tow. so they are not really motivated.....
Apr 15, 2026
454 Water pump hoses
Post a pic of the front of your motor with also showing the thermostat housing
Apr 15, 2026
Mercruiser motor swap
Moved it to Merc from FAQ area
Apr 15, 2026
T
Tdunne96
posted the thread
Johnson 25 Prop size
in
Prop Questions and Topics
Good day everyone, I am currently troubleshooting low top speed and unable to get on plane with my Lowe Angler 140S 14’ side console...
Apr 15, 2026
B
beta
1995 Crownline 202BR Restore
Starting to clean up the gimbal housing, transom plate, etc and getting all the new gaskets, etc on order. Regarding the exhaust pipe...
Apr 15, 2026
B
beta
Took a vacation and got behind on posting. Completed the gel coating on the engine area. Did a dry fit on the the gimbal housing and...
Apr 15, 2026
F
foste1cc
reacted to
FLATHEAD's post
in the thread
My carb is obsolete.. Please help me repair/replace!
with
Like
Better yet put ethanol free gas in it when you get it running. It’s what I use on all my stuff , boat,mower, chain saws, blower, weed...
Apr 15, 2026
F
foste1cc
reacted to
airshot's post
in the thread
with
Like
If you do proper maintenance it will be a long time before another rebuild will be needed. Watch where you buy your fuel, often times...
Apr 15, 2026
should be easy. however the boat is nearly 21 feet long. go with a 5.7 if you are sticking to Gen 1 SBC motor over the 5.0 @Scott06...
Apr 15, 2026
Apr 15, 2026
J
jlh3rd
Apr 15, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
I have both a cordless and corded angle grinders. Running 40 grit flap disks. . Progress so far . . . . . I've been using the...
Apr 15, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
with
Like
Here is the difference in those 2 boats (Formula 310 I/O vs OB) The outboard version has the hull extended at the full height of the...
Apr 15, 2026
