D
DeepCMark58A
reacted to
tphoyt's post
in the thread
I’m still in the game
with
Like
A couple months ago durning a snow storm i stopped to help a lady change a tire. She went on her merry way and all was well. I was at...
Apr 15, 2026
T
Tdunne96
reacted to
racerone's post
in the thread
Johnson 25 Prop size
with
Like
It will rev up fine on a hose when running on one cylinder.----Take it back and insist they check it over.
Apr 15, 2026
T
Tdunne96
reacted to
flashback's post
in the thread
with
Like
Might try it without the whale tail.
Apr 15, 2026
M
MikeSchinlaub
replied to the thread
1995 Crownline 202BR Restore
If you use any gasket maker, I would suggest one rated for high heat. I don't do engine work though, so can't suggest any more than that.
Apr 15, 2026
T
tphoyt
posted the thread
in
Dockside Chat
Apr 15, 2026
flashback
Apr 15, 2026
R
Apr 15, 2026
T
Tdunne96
I will do a compression test and check spark when I take it back out after it stops raining. I was only thinking prop issue because it...
Apr 15, 2026
C
Mercruiser motor swap
You might look up the weight of the V6 and V8 and see the difference. I expect it to be nominal. You might ask the experts if the...
Apr 15, 2026
Volvo aq270T gimbal bearing
thats your drive coupling that is bolted to the flywheel
Apr 15, 2026
C
My carb is obsolete.. Please help me repair/replace!
Here is a carb repair kit with lots of extra stuff. Springs, jets and other stuff. the price is extra as well. BTW, Gasoline with...
Apr 15, 2026
C
ChadAustin
Ok here’s what I have, is this 2 pieces or 1 and is there even a vibration dampener on this flywheel or is this it
Apr 15, 2026
R
Oil alarm beeping at low RPM
Could you explain what motor you have.-----Year / power / serial #
Apr 15, 2026
M
Mc Tool
1st thing I would do is to get a gauge and measure the oil pressure . Low oil pressure at idle can be a sign of bad things and you would...
Apr 15, 2026
C
Motor lift plate
manual Jackplates, right? They will move center of balance back a bit and the boat will set a bit lower in the water, at the stern.
Apr 15, 2026
