R
replied to the thread
Johnson 25 Prop size
Doubt it is a prop issue.----Trouble shoot the motor.-----Might be running on 1 cylinder.----Post actual compression numbers.----Does...
Apr 15, 2026
R
rphillips
posted the thread
Oil alarm beeping at low RPM
in
Mercury & Mariner Outboards
A while back I had a power pack go bad, till then all was good. I had the bad one replaced and ever since the oil alarm beeps till I...
Apr 15, 2026
P
Pmt133
Mercruiser motor swap
I agree with Scott, no one ever wished they had less power. And when a 305 and 350 are the same size and weight why wouldn't you...
Apr 15, 2026
C
Chuck4741444
posted the thread
Motor support racks
in
Boat Topics and Questions (not engine topics)
Im needing to build a rach to hold (2) johnson 150 and (1) 200. How wide and how far apart should the wheels be to support these three...
Apr 15, 2026
P
Pmt133
reacted to
Scott Danforth's post
in the thread
with
Like
should be easy. however the boat is nearly 21 feet long. go with a 5.7 if you are sticking to Gen 1 SBC motor over the 5.0 @Scott06...
Apr 15, 2026
P
Pmt133
1995 Crownline 202BR Restore
Should go on dry, my original on my 3.0l was that way for 40 years with no issue. I do usually bed the oring in something just so it...
Apr 15, 2026
P
Pmt133
reacted to
beta's post
in the thread
with
Like
Took a vacation and got behind on posting. Completed the gel coating on the engine area. Did a dry fit on the the gimbal housing and...
Apr 15, 2026
P
Pmt133
reacted to
in the thread
Pushing Run-Flat tires to the limit
with
Like
AAA is an opt-in for most towing companies. they only get $35 per tow. so they are not really motivated.....
Apr 15, 2026
flashback
Paintball gun
You want glow in the dark raccoons running around, cool. Probably drive them crazy. :)
Apr 15, 2026
Alpha One Gen II Lower Unit - Drive Shaft Binds When Tightening Retainer
I'm having trouble following your comments, maybe it's the terms This is talking lower You pulled the lower apart but did not...
Apr 15, 2026
S
SlipperyOar
1981 Springbok 18' Restoration/Renovation
Got some side panels made up today. Needed something to cover up the sides of the hull and also give me a spot to mount my motor...
Apr 15, 2026
flashback
reacted to
in the thread
with
Like
Apr 15, 2026
454 Water pump hoses
Post a pic of the front of your motor with also showing the thermostat housing
Apr 15, 2026
Moved it to Merc from FAQ area
Apr 15, 2026
T
Tdunne96
posted the thread
in
Prop Questions and Topics
Good day everyone, I am currently troubleshooting low top speed and unable to get on plane with my Lowe Angler 140S 14’ side console...
Apr 15, 2026
