A
airshot
reacted to
flashback's post
in the thread
Johnson 25 Prop size
with
Like
Might try it without the whale tail.
Apr 15, 2026
A
airshot
reacted to
racerone's post
in the thread
with
Like
It will rev up fine on a hose when running on one cylinder.----Take it back and insist they check it over.
Apr 15, 2026
A
airshot
reacted to
racerone's post
in the thread
with
Like
Doubt it is a prop issue.----Trouble shoot the motor.-----Might be running on 1 cylinder.----Post actual compression numbers.----Does...
Apr 15, 2026
A
airshot
replied to the thread
My carb is obsolete.. Please help me repair/replace!
Before E10 fuels came out, people still had carb gumming issues, that is the reason " Gumout" was invented way back in the 50-60's...
Apr 15, 2026
redneck joe
1995 Crownline 202BR Restore
On my resto thread i started side one and linked to main. Might want to post over in the mercruiser forum.
Apr 15, 2026
Fun Times
reacted to
tphoyt's post
in the thread
I’m still in the game
with
Like
A couple months ago durning a snow storm i stopped to help a lady change a tire. She went on her merry way and all was well. I was at...
Apr 15, 2026
D
DeepCMark58A
reacted to
tphoyt's post
in the thread
with
Like
Apr 15, 2026
T
Tdunne96
reacted to
racerone's post
in the thread
with
Like
Apr 15, 2026
T
Tdunne96
reacted to
flashback's post
in the thread
with
Like
Apr 15, 2026
M
MikeSchinlaub
If you use any gasket maker, I would suggest one rated for high heat. I don't do engine work though, so can't suggest any more than that.
Apr 15, 2026
T
tphoyt
posted the thread
in
Dockside Chat
Apr 15, 2026
flashback
Apr 15, 2026
R
Apr 15, 2026
T
Tdunne96
I will do a compression test and check spark when I take it back out after it stops raining. I was only thinking prop issue because it...
Apr 15, 2026
C
Mercruiser motor swap
You might look up the weight of the V6 and V8 and see the difference. I expect it to be nominal. You might ask the experts if the...
Apr 15, 2026
