replied to the thread
Volvo aq270T gimbal bearing
thats your drive coupling that is bolted to the flywheel
Apr 15, 2026
C
My carb is obsolete.. Please help me repair/replace!
Here is a carb repair kit with lots of extra stuff. Springs, jets and other stuff. the price is extra as well. BTW, Gasoline with...
Apr 15, 2026
C
ChadAustin
Ok here’s what I have, is this 2 pieces or 1 and is there even a vibration dampener on this flywheel or is this it
Apr 15, 2026
R
Oil alarm beeping at low RPM
Could you explain what motor you have.-----Year / power / serial #
Apr 15, 2026
M
Mc Tool
1st thing I would do is to get a gauge and measure the oil pressure . Low oil pressure at idle can be a sign of bad things and you would...
Apr 15, 2026
C
Motor lift plate
manual Jackplates, right? They will move center of balance back a bit and the boat will set a bit lower in the water, at the stern.
Apr 15, 2026
R
Johnson 25 Prop size
Doubt it is a prop issue.----Trouble shoot the motor.-----Might be running on 1 cylinder.----Post actual compression numbers.----Does...
Apr 15, 2026
R
rphillips
posted the thread
in
Mercury & Mariner Outboards
A while back I had a power pack go bad, till then all was good. I had the bad one replaced and ever since the oil alarm beeps till I...
Apr 15, 2026
P
Pmt133
Mercruiser motor swap
I agree with Scott, no one ever wished they had less power. And when a 305 and 350 are the same size and weight why wouldn't you...
Apr 15, 2026
C
Chuck4741444
posted the thread
Motor support racks
in
Boat Topics and Questions (not engine topics)
Im needing to build a rach to hold (2) johnson 150 and (1) 200. How wide and how far apart should the wheels be to support these three...
Apr 15, 2026
P
Pmt133
reacted to
Scott Danforth's post
in the thread
with
Like
should be easy. however the boat is nearly 21 feet long. go with a 5.7 if you are sticking to Gen 1 SBC motor over the 5.0 @Scott06...
Apr 15, 2026
P
Pmt133
1995 Crownline 202BR Restore
Should go on dry, my original on my 3.0l was that way for 40 years with no issue. I do usually bed the oring in something just so it...
Apr 15, 2026
P
Pmt133
reacted to
beta's post
in the thread
with
Like
Took a vacation and got behind on posting. Completed the gel coating on the engine area. Did a dry fit on the the gimbal housing and...
Apr 15, 2026
P
Pmt133
reacted to
in the thread
Pushing Run-Flat tires to the limit
with
Like
AAA is an opt-in for most towing companies. they only get $35 per tow. so they are not really motivated.....
Apr 15, 2026
flashback
Paintball gun
You want glow in the dark raccoons running around, cool. Probably drive them crazy. :)
Apr 15, 2026
