kbh121956
reacted to
racerone's post
in the thread
1987 Force 50hp head warpage.
with
Like
All outboard heads warp.----Resurface it with emery paper on a piece of thick glass.
Apr 15, 2026
kbh121956
reacted to
Nordin's post
in the thread
with
Like
Yes like racerone says. Resurface it at a piece of glass and water sanding paper. sand it and do it in a 8 pattern way. Check it with a...
Apr 15, 2026
flashback
reacted to
racerone's post
in the thread
Johnson 25 Prop size
with
Like
It will rev up fine on a hose when running on one cylinder.----Take it back and insist they check it over.
Apr 15, 2026
flashback
reacted to
airshot's post
in the thread
with
Like
Just based on the pic, it looks like the motor is trimmed in to far. Do you have a tach for the motor ? Whale tails are a last resort...
Apr 15, 2026
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
I'm pretty behind on updates, amd pictures. I thought the Stingray was finished, so next is a Cobalt. The tower was damaged, and in the...
Apr 15, 2026
M
MikeSchinlaub
replied to the thread
Boats from work.
Apr 15, 2026
C
ChadAustin
Volvo aq270T gimbal bearing
I figured it was the coupling but do these engines have a damper plate or is that the same as the drive coupling. my boat shops around...
Apr 15, 2026
T
Tdunne96
I have a tach on the way. The current trim gives me the highest speed and best ride. I’ve tried every position. I will remove the tail...
Apr 15, 2026
A
airshot
Apr 15, 2026
A
airshot
reacted to
flashback's post
in the thread
with
Like
Might try it without the whale tail.
Apr 15, 2026
A
airshot
reacted to
racerone's post
in the thread
with
Like
Apr 15, 2026
A
airshot
reacted to
racerone's post
in the thread
with
Like
Doubt it is a prop issue.----Trouble shoot the motor.-----Might be running on 1 cylinder.----Post actual compression numbers.----Does...
Apr 15, 2026
A
airshot
My carb is obsolete.. Please help me repair/replace!
Before E10 fuels came out, people still had carb gumming issues, that is the reason " Gumout" was invented way back in the 50-60's...
Apr 15, 2026
redneck joe
1995 Crownline 202BR Restore
On my resto thread i started side one and linked to main. Might want to post over in the mercruiser forum.
Apr 15, 2026
Fun Times
reacted to
tphoyt's post
in the thread
I’m still in the game
with
Like
A couple months ago durning a snow storm i stopped to help a lady change a tire. She went on her merry way and all was well. I was at...
Apr 15, 2026
