redneck joe
replied to the thread
2026 NFL/CFB News and Nonsense
Apr 15, 2026
T
Tdunne96
Johnson 25 Prop size
That is about what I expected 20-25. I get about 15-17 tops at the moment with only me on the boat. Supposed to clear up this weekend I...
Apr 15, 2026
R
Boat should run near 25 m/hr.-----Maje sure there is a new water pump impeller installed too.
Apr 15, 2026
P
Pmt133
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
I'm pretty behind on updates, amd pictures. I thought the Stingray was finished, so next is a Cobalt. The tower was damaged, and in the...
Apr 15, 2026
flashback
1995 Crownline 202BR Restore
as you probably know most any component on the motor such as starter, mechanical fuel pump, etc. will be easier to replace while the...
Apr 15, 2026
kbh121956
1987 Force 50hp head warpage.
Thank you Nordin. You answered both of my questions.
Apr 15, 2026
kbh121956
reacted to
racerone's post
in the thread
with
Like
All outboard heads warp.----Resurface it with emery paper on a piece of thick glass.
Apr 15, 2026
kbh121956
reacted to
Nordin's post
in the thread
with
Like
Yes like racerone says. Resurface it at a piece of glass and water sanding paper. sand it and do it in a 8 pattern way. Check it with a...
Apr 15, 2026
flashback
reacted to
racerone's post
in the thread
with
Like
It will rev up fine on a hose when running on one cylinder.----Take it back and insist they check it over.
Apr 15, 2026
flashback
reacted to
airshot's post
in the thread
with
Like
Just based on the pic, it looks like the motor is trimmed in to far. Do you have a tach for the motor ? Whale tails are a last resort...
Apr 15, 2026
reacted to
in the thread
Boats from work.
with
Like
Apr 15, 2026
M
MikeSchinlaub
Boats from work.
Apr 15, 2026
C
ChadAustin
Volvo aq270T gimbal bearing
I figured it was the coupling but do these engines have a damper plate or is that the same as the drive coupling. my boat shops around...
Apr 15, 2026
T
Tdunne96
I have a tach on the way. The current trim gives me the highest speed and best ride. I’ve tried every position. I will remove the tail...
Apr 15, 2026
A
airshot
Apr 15, 2026
