B
BrianVT
replied to the thread
Old 4hp Evinrude takes a nap
This old 'rude looked pretty rough but I got it cheap. It had good compression (@ 120 psi on both, I think?). I hoped I could save it...
Apr 15, 2026
WIMUSKY
2026 NFL/CFB News and Nonsense
I give up, who is he?
Apr 15, 2026
C
Oil 4 stroke Mercury 115hp
That motor likely requires a FC-W oil. Any oil rated as such is acceptable. Automotive multivis oils are generally not recommended.
Apr 15, 2026
6
68glasspar
No spark 55 HP Evinrude triumph 1969
After dark have someone crank the engine over while you look under the flywheel and see if the spark is shorting thru the plug wire boots.
Apr 15, 2026
Not so sad boater
Using a timing light during cranking I only have signal at cylinder 1
Apr 15, 2026
A
airshot
Johnson 25 Prop size
On initial setup I always trim the motor so the cav plate is parallel to the bottom of the boat using a long straight edge. Put it up...
Apr 15, 2026
A
airshot
reacted to
racerone's post
in the thread
with
Like
Boat should run near 25 m/hr.-----Maje sure there is a new water pump impeller installed too.
Apr 15, 2026
C
Captf22
posted the thread
in
Mercury & Mariner Outboards
4 stroke oil, New Mercury 115hp 10w-30 or 25w-40 Synthetic Blend any opinions?
Apr 15, 2026
M
MikeSchinlaub
1995 Crownline 202BR Restore
Have you checked that the surfaces are flat? Maybe there was some warping or pitting or something.
Apr 15, 2026
dingbat
reacted to
JASinIL2006's post
in the thread
Ideas for planters/raised beds?
with
Like
I have used grow bags also, and my experience matched yours. They work great, especially because the plants don’t tend to get root bound...
Apr 15, 2026
Ifishmuskie2
reacted to
SlipperyOar's post
in the thread
1981 Springbok 18' Restoration/Renovation
with
Like
Got some side panels made up today. Needed something to cover up the sides of the hull and also give me a spot to mount my motor...
Apr 15, 2026
Ifishmuskie2
reacted to
tphoyt's post
in the thread
I’m still in the game
with
Like
A couple months ago durning a snow storm i stopped to help a lady change a tire. She went on her merry way and all was well. I was at...
Apr 15, 2026
B
beta
The Permatex ultra blue is rated to 400 so I would hope that is plenty high enough. I guess I'll do it dry and cross my fingers...
Apr 15, 2026
Fun Times
Oil alarm beeping at low RPM
Sometimes this issue may show up from things such as oil level not completely topped off in the bottle/s, a failing sensor inside...
Apr 15, 2026
redneck joe
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
I'm pretty behind on updates, amd pictures. I thought the Stingray was finished, so next is a Cobalt. The tower was damaged, and in the...
Apr 15, 2026
