roscoe
reacted to
Chris1956's post
in the thread
Oil 4 stroke Mercury 115hp
with
Like
That motor likely requires a FC-W oil. Any oil rated as such is acceptable. Automotive multivis oils are generally not recommended.
Apr 16, 2026
roscoe
replied to the thread
Motor support racks
Depends what you are building the rack out of. A welded steel rack, may only need a wheel in each corner. Something out of 2x6's on end...
Apr 16, 2026
J
Jacobnya
1989 omc cobra gear case problem
i will go down to the boat shop tomorrow and ask some questions about the pinion gear and nut also about what shims he has. he...
Apr 15, 2026
J
Jacobnya
i got the part numbers off the damaged gears and bought those then i bought the lower unit seal kit and upper unit seal kit and also...
Apr 15, 2026
BWR1953
reacted to
tphoyt's post
in the thread
I’m still in the game
with
Like
A couple months ago durning a snow storm i stopped to help a lady change a tire. She went on her merry way and all was well. I was at...
Apr 15, 2026
D
DeepCMark58A
You know what a lot of time good karma means you avoid misfortune, in this case this karma came back direct but I suspect you have paid...
Apr 15, 2026
C
ChadAustin
Volvo aq270T gimbal bearing
Ok it looks to be fine, PDS fits well no slop, any chance that plate could cause massive vibration, I assume it’s the bearing but incase...
Apr 15, 2026
D
DeepCMark58A
2026 NFL/CFB News and Nonsense
Why would an average person know who that is or care? Not to be rude but who is that? Alex Smith my guess who has a very unremarkable...
Apr 15, 2026
A
airshot
Old 4hp Evinrude takes a nap
How accurate is your compression gage ? Did it over heat ? You might try some ring free or other additive to regain some compression.
Apr 15, 2026
M
Mc Tool
Nobody fishing?
It was blowing it arse off here today This is down at Howells point , Riverton and we are pointing straight at Stewart Island....,.if...
Apr 15, 2026
redneck joe
Random
https://www.facebook.com/share/v/1JkovcAhwt/
Apr 15, 2026
FLATHEAD
reacted to
tphoyt's post
in the thread
with
Like
Apr 15, 2026
S
saltchuckmatt
105 should still run
Apr 15, 2026
You can call it a splined thingy if it helps. A drive plate=damper=glorified clutch disc without friction material
Apr 15, 2026
redneck joe
If you are serious, I will post a synopsis.
Apr 15, 2026
