  • Scott Danforth
    Chances are low it's the drive plate, inspect as needed Check the PDS bearings
  • redneck joe
    redneck joe replied to the thread daily music fix.
    There are a few songs that when I hear them I can feel by body change. Wife says she can see it when I get in the boat as we pull away...
  • M
    Mc Tool replied to the thread Ideas for planters/raised beds?.
    Ha ,last time I used grow bags it was a 60 kg coal sack filled with super dirt , used to scramble/crawl into the middle of a big gorse...
  • M
    Mc Tool replied to the thread Motor support racks.
    As wide as you need to fit the 3 motors ,I mean its not like they are going to fall over sideways with the 3 side by side on the same...
  • tpenfield
    tpenfield reacted to tphoyt's post in the thread I’m still in the game with Like Like.
    A couple months ago durning a snow storm i stopped to help a lady change a tire. She went on her merry way and all was well. I was at...
  • redneck joe
    redneck joe reacted to Mc Tool's post in the thread Nobody fishing? with Like Like.
    It was blowing it arse off here today This is down at Howells point , Riverton and we are pointing straight at Stewart Island....,.if...
  • R
    racerone replied to the thread Old 4hp Evinrude takes a nap.
    Impeller is all it needs.
  • M
    Mc Tool replied to the thread I’m still in the game.
    I was at Macca's a while ago , they had a promo with stickers on the wrapping ,some of which were instant prizes , anyhow I wasnt...
  • M
    Mc Tool reacted to tphoyt's post in the thread I’m still in the game with Like Like.
  • roscoe
    roscoe reacted to Chris1956's post in the thread Oil 4 stroke Mercury 115hp with Like Like.
    That motor likely requires a FC-W oil. Any oil rated as such is acceptable. Automotive multivis oils are generally not recommended.
  • roscoe
    roscoe replied to the thread Motor support racks.
    Depends what you are building the rack out of. A welded steel rack, may only need a wheel in each corner. Something out of 2x6's on end...
  • J
    i will go down to the boat shop tomorrow and ask some questions about the pinion gear and nut also about what shims he has. he...
  • J
    i got the part numbers off the damaged gears and bought those then i bought the lower unit seal kit and upper unit seal kit and also...
  • BWR1953
    BWR1953 reacted to tphoyt's post in the thread I’m still in the game with Like Like.
  • D
    DeepCMark58A replied to the thread I’m still in the game.
    You know what a lot of time good karma means you avoid misfortune, in this case this karma came back direct but I suspect you have paid...
