B
BrianVT
reacted to
racerone's post
in the thread
Old 4hp Evinrude takes a nap
with
Like
Impeller is all it needs.
Apr 16, 2026
B
BrianVT
replied to the thread
I think the gauge is good. It has the Schrader valve at the tip so it should be accurate even for small volume cylinders. I assume it...
Apr 16, 2026
J
Jeff J
Nobody fishing?
I don’t think I have ever had braid do me that bad… even on the bait casters. Mono, on the other hand, sometimes likes to twist on the...
Apr 16, 2026
J
Jeff J
reacted to
FLATHEAD's post
in the thread
Nobody fishing?
with
Like
How does that even happen.😮
Apr 16, 2026
T
tphoyt
reacted to
redneck joe's post
in the thread
daily music fix
with
Like
There are a few songs that when I hear them I can feel by body change. Wife says she can see it when I get in the boat as we pull away...
Apr 16, 2026
1977 century with OMC freeze out plugs
the core plugs will hold 50 psi without issue. you can not generate enough pressure for that to ever happen if the block is in good...
Apr 16, 2026
Bugzilla46310
reacted to
tphoyt's post
in the thread
I’m still in the game
with
Like
A couple months ago durning a snow storm i stopped to help a lady change a tire. She went on her merry way and all was well. I was at...
Apr 16, 2026
Bugzilla46310
Motor support racks
If the combined center of gravity stay within the perimeter of the base, an item will not fall over.
Apr 16, 2026
A
Ajstangl
Thanks. I know it is the original engine my father bought the boat new. Maybe I popped it out with too much hose pressure. But I had it...
Apr 16, 2026
C
ChadAustin
reacted to
Scott Danforth's post
in the thread
Volvo aq270T gimbal bearing
with
Like
You can call it a splined thingy if it helps. A drive plate=damper=glorified clutch disc without friction material
Apr 16, 2026
A
Ajstangl
reacted to
in the thread
with
Like
if the core plugs rotted out, then the motor was replaced at one time with a non-marine motor the ones from GM when the motor was new...
Apr 16, 2026
A
Ajstangl
OK thank you. I think I used the wrong name. The boot is that called a transome seal?
Apr 16, 2026
Motor support racks
with wheels, the rack has to be big enough in both directions to keep the load from falling over when you move it and hit a crack, or a...
Apr 16, 2026
A
Ajstangl
reacted to
southkogs's post
in the thread
with
Like
I've never changed the freeze plugs on that engine. But, you shouldn't have bellows on that drive system. That's a Stringer, so you...
Apr 16, 2026
T
tphoyt
reacted to
redneck joe's post
in the thread
Random
with
Like
https://www.facebook.com/share/v/1JkovcAhwt/
Apr 16, 2026
