B
beta
replied to the thread
1995 Crownline 202BR Restore
FYI... got an answer from the engine forum. It's 92-25234 Sound blanket glue, but this has been superseded by Bellows adhesive 86166Q1...
Apr 16, 2026
B
beta
Exhaust to Gimbal Connection
Thanks! I also see it now in the materials list but no mention of it in the instructions. There was a good bit of whatever was on it...
Apr 16, 2026
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
Measuring the resistance of a blower tells you nothing. If you want to see how much current it is drawing use a DC clamp meter. As far...
Apr 16, 2026
P
Pmt133
Mercruiser motor swap
The amount of restraint I exercised by only going to a V6 in my 4 winns needs to be studied. It was either 4.3 or 388, nothing else...
Apr 16, 2026
It just list to use it, no mention of how much I would probably use a liberal amount, won't hurt
Apr 16, 2026
Scott06
is that just to hold the oring/gasket in place?
Apr 16, 2026
Scott06
there used to be engine install drawings on the merc site with dimensions for where the motor mounts go off the X dimension (crank/...
Apr 16, 2026
Scott06
the 5.7 is the gateway drug to the 383...
Apr 16, 2026
nola mike
No 383 suggestion?
Apr 16, 2026
bigblocksarefun
Saw one of those for sale with a Merc Reman 300hp 350 hooked to a Bravo 3. You could upgrade to the newer 4.5 V6 at 225hp; personally...
Apr 16, 2026
C
Crosbyman
Evinrude 50 4 stroke 1999 been setting, need to restart suggestions/ guidence
first thing is to get a manual and compare results to specs. it may flag a problem more than swapping or guessing but... ex: see sect...
Apr 16, 2026
A
airshot
reacted to
saltchuckmatt's post
in the thread
Old 4hp Evinrude takes a nap
with
Like
What oil you running and what ratio's?
Apr 16, 2026
redneck joe
1973 Starcraft SuperSport 16ft. restoration questions
Well I assume your evacuation plan includes having a boat in the driveway.... I did the old timers formula as well as a marine epoxy...
Apr 16, 2026
redneck joe
2026 NFL/CFB News and Nonsense
Yes it is Alex Smith, and the injury almost killed him.
Apr 16, 2026
WIMUSKY
I guess a name would be sufficient, is DeepC correct?
Apr 16, 2026
