redneck joe
reacted to
beta's post
in the thread
Exhaust to Gimbal Connection
with
Like
Thanks! I also see it now in the materials list but no mention of it in the instructions. There was a good bit of whatever was on it...
Apr 16, 2026
tpenfield
replied to the thread
I/O (Sterndrive) Conversion to Outboards
I made the mistake of touching an area of the fiberglass that had been ground . . . ouch . . . microscopic fibers in my finger :oops...
Apr 16, 2026
Scott06
Mercruiser motor swap
yes I'm a big guy and the boat could pull me up on two skiis just fine. This was with a 16" pitch 4 blade Michigan Vortex. Ran a 18" 4...
Apr 16, 2026
nola mike
reacted to
alldodge's post
in the thread
Alpha One Gen II Lower Unit - Drive Shaft Binds When Tightening Retainer
with
Like
I'm having trouble following your comments, maybe it's the terms This is talking lower You pulled the lower apart but did not...
Apr 16, 2026
nola mike
reacted to
Scott06's post
in the thread
with
Like
the 5.7 is the gateway drug to the 383...
Apr 16, 2026
Not so sad boater
No spark 55 HP Evinrude triumph 1969
I did that last night I did not see spark escaping from anywhere. What I have found is a slight wiggle on my rotor when fully seated...
Apr 16, 2026
P
Pmt133
36 grit belt on a belt sander worked well on flat surfaces FYI. May make short work of the outside.
Apr 16, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
Interior grinding is done. I still have the grinding outside the transom to do . . .
Apr 16, 2026
P
Pmt133
Once it was on plane ot was... fine. With 4 adults you were doing 24-26 mph without killing it with RPMs. I burn the same amount of fuel...
Apr 16, 2026
P
Pmt133
reacted to
Scott06's post
in the thread
with
Like
yes I had a 3.0 in a 17-18 ft bowrider. Wasnt really adequate there either, but I do miss putting $50 of gas in going all weekend and...
Apr 16, 2026
reacted to
tpenfield's post
in the thread
with
Like
Apr 16, 2026
tpenfield
Apr 16, 2026
roscoe
reacted to
Tdunne96's post
in the thread
Johnson 25 Prop size
with
Like
That is about what I expected 20-25. I get about 15-17 tops at the moment with only me on the boat. Supposed to clear up this weekend I...
Apr 16, 2026
yes, the Q7 did come with the 6.2 as an option. most of the motors were the 50 MPI engine, and some received the entry level 4.3...
Apr 16, 2026
Scott06
Apr 16, 2026
