E
ejnichol
replied to the thread
My carb is obsolete.. Please help me repair/replace!
IF you run 10% ethanol gas just watch the age of the gas in the tank, lines and carb. I make sure I turn mine fuel over to fresh at...
Apr 17, 2026
dingbat
Nobody fishing?
No winds to speak of. The breaking waves are the two currents concluding. “The Point” is formed by the convergence of the warm Gulf...
Apr 17, 2026
E
ejnichol
reacted to
airshot's post
in the thread
with
Like
Before E10 fuels came out, people still had carb gumming issues, that is the reason " Gumout" was invented way back in the 50-60's...
Apr 17, 2026
E
ejnichol
reacted to
Chris1956's post
in the thread
with
Like
Here is a carb repair kit with lots of extra stuff. Springs, jets and other stuff. the price is extra as well. BTW, Gasoline with...
Apr 17, 2026
dingbat
reacted to
Mc Tool's post
in the thread
Nobody fishing?
with
Like
It was blowing it arse off here today This is down at Howells point , Riverton and we are pointing straight at Stewart Island....,.if...
Apr 17, 2026
S
SlipperyOar
posted the thread
Need help finding tachometer
in
Electrical, Electronics, Audio and Trolling Motors
I am rebuilding my boat currently and getting ready to drill holes in my dash for gauges, steering, switches, ect. and am looking for...
Apr 17, 2026
redneck joe
1973 Starcraft SuperSport 16ft. restoration questions
I used rustoleum Topside marine paint for the floors. Im sure it would be ok on the aluminum with the proper primer but not qualified...
Apr 17, 2026
Power steering fluid in bilge?
No, only one oil side.
Apr 17, 2026
R
No spark 55 HP Evinrude triumph 1969
I would never spend $400 on new ignition parts for that motor !!
Apr 17, 2026
M
Mc Tool
Old 4hp Evinrude takes a nap
Overheating can also cause the piston rings to loose tension which wont help compression 🙂
Apr 17, 2026
jimmbo
Johnson 25 Prop size
The may entail removal of the Carb, which then a check and possible adjustment known as a Link and Sync, will likely be in order...
Apr 16, 2026
Fun Times
Exhaust to Gimbal Connection
The cable seen in your first photo with the white wrap around it....The lower shift cable runs to the drive from the engine...Item...
Apr 16, 2026
B
beta
Not sure I know what you are referring to here.. can you elaborate?
Apr 16, 2026
Not so sad boater
I verified the gap on my points on all lobes twice just to be sure that nothing exceeded the recommended adjustment. I'm thinking I got...
Apr 16, 2026
Not so sad boater
No play in crank the wiggle is at the notched area it can turn side to side in the notch it sits in, my understanding is that it has...
Apr 16, 2026
