Not so sad boater
replied to the thread
No spark 55 HP Evinrude triumph 1969
The first part of that makes a lot of sense trying to manually trigger the spark on certain cylinders so I might give that a shot...
Apr 19, 2026
matt167
Yamaha 9.9 troubles
Not sure as I haven’t checked it. I really don’t think it’s down on compression as it does actually run fine and has plenty of power. I...
Apr 19, 2026
C
Crosbyman
good or not here is one suggestion... disconnect the pulse wire from the points to the amplifier Position the rotor to fire on one...
Apr 19, 2026
M
Mc Tool
Yamaha 9.9 troubles
Sounds like its already been cooked . Whats the compression like ?
Apr 19, 2026
Not so sad boater
I did do this I just wanted to let you know I did not ignore your advice this is one of the things that I did when I went back into it...
Apr 19, 2026
Not so sad boater
I'm sorry I suffer from PTSD and I get really frustrated really easy I took my medicine so I've calmed down and been able to take a...
Apr 19, 2026
I/O (Sterndrive) Conversion to Outboards
Cruisers resin does have a reddish tint
Apr 19, 2026
Not so sad boater
reacted to
68glasspar's post
in the thread
with
Like
But you still refuse to spend 15min time and .05 cents worth of silcone dielectric inside the spark plug boot at the dist. cap!
Apr 19, 2026
Not so sad boater
I did do this since I already had the flywheel off it made it really easy for me to remove the boots and pack around the wire where it...
Apr 19, 2026
Not so sad boater
I did the All the tests on the amplifier I am getting a solid 12 volt so I even did the recommendation of running a wire directly from...
Apr 19, 2026
P
Pmt133
reacted to
alldodge's post
in the thread
Merc 250 Verado Fuel increase
with
Like
Oh that's demand liner, demand, and demand Guardian I will use those readings to find out if my change it props is a good or bad thing...
Apr 19, 2026
P
Pmt133
Yeah I had a wee bit of brain fart on that one. :p I too usually only see resin as amber/blue green or purple. The red is new lol...
Apr 19, 2026
M
Mc Tool
1974 Chrysler 135 hp limping
They all look a bit clean to me ,specially the two on the left .....interesting 😃
Apr 19, 2026
M
Mc Tool
Nobody fishing?
I agree that not all braid is the same , I have two other combos that have some tournament crystal braid .......wanna say Berkley but...
Apr 19, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
You wouldn't have tooling resin in a production piece. :unsure: That (red) is the fiberglass (resin). Not sure what it is, but...
Apr 19, 2026
