ezbtr
replied to the thread
2012 F150 3.5 EB turbo(2) oil change, low miles on oil
OK, so I’ll make damn sure he gets hot for 30 minutes every Sunday as opposed to 20 minutes every Sunday
Apr 19, 2026
ezbtr
reacted to
matt167's post
in the thread
with
Like
The oil needs to get up to operating temp and hold there for twice that time to burn the moisture off.. anything less is short trip/...
Apr 19, 2026
ezbtr
I know all about the oil threads guys, I’m just saying I’ll make sure it gets hot for 15 minutes a week at least
Apr 19, 2026
ezbtr
reacted to
alldodge's post
in the thread
with
Like
Oh man another oil thread That said The motor needs to get up to full operating temp long enough to burn the moisture off. If this is...
Apr 19, 2026
jimmbo
Johnson 25 Prop size
Add a leaky Crankshaft Seal to the List of things that can cause Issues with the upper Cylinder
Apr 19, 2026
Bugzilla46310
reacted to
Scott Danforth's post
in the thread
Motor support racks
with
Like
As long as it doesn't move. Once it moves (wheels), you have to take velocity and mass into it to see if coming to an instant stop...
Apr 19, 2026
Stinnett21
Ebbtide 2008
Average build middle of the road bowrider. Made in TN I believe. As stated above, all depends on how it was stored.
Apr 19, 2026
C
Crosbyman
reacted to
68glasspar's post
in the thread
No spark 55 HP Evinrude triumph 1969
with
Like
Another idea is if he doesn't want to run another wire, We (auto mechanic) would take a halogen headlight bulb to load test the circuit...
Apr 19, 2026
6
68glasspar
Apr 19, 2026
C
Crosbyman
sad boater ... just keep in mind that voltage readings are subjectives sometimes. Seeing 11.8 volts gives you the measured volts at...
Apr 19, 2026
6
68glasspar
Also check the continuity of the wire for the points that travels up to the breaker plate. pay close attention were the wire is clamped...
Apr 19, 2026
C
carlos515
Ebbtide 2008
True, But I was just looking for some insight into the build quality. But yes, almost 20 years of water use. I will bring an awl with me.
Apr 19, 2026
Fun Times
reacted to
AusFox's post
in the thread
Mercruiser 350 MAG MPI
with
Like
Testing in good conditions shows we are getting 4800 RPM. The owner said we are still about 2-3 knots (GPS tested) speed off what he has...
Apr 19, 2026
Fun Times
reacted to
AusFox's post
in the thread
with
Like
Boat is running great! I just now want to put a fuel flow meter in and check the fuel consumption. It currently has a flow meter that’s...
Apr 19, 2026
C
carlos515
posted the thread
Ebbtide 2008
in
Boat Topics and Questions (not engine topics)
Hi all, I have sold my old project Sun Ray 20 footer. I am looking at the above titled boat. It is an 18 footer with a v6 in it. The...
Apr 19, 2026
