R
replied to the thread
No spark 55 HP Evinrude triumph 1969
I worked at a dealer where we sold those motors NEW.-----Can rebuild engine and lower unit without using / needing a manual.
Apr 20, 2026
Not so sad boater
My dog got ahold of it so it now has a damaged plastic end where the boot goes. But I think I'm going to try it anyway if it acts any...
Apr 20, 2026
Mercruiser 5 L mpi cooling system
flappers and the rubber exhaust couplings. both rated to 250F max. however without water running, your exhaust goes from 200F to 950F
Apr 20, 2026
Not so sad boater
I wasn't trying to be rude. You kept supplying information not related to the engine at all, so all though you were trying to be helpful...
Apr 20, 2026
Not so sad boater
I did look for new points on eBay and I thought about buying them because besides the points would have to be a bad new part. The ends...
Apr 20, 2026
A
affa
Ok thanks, the rubber in the exhaust, is that the flappers?
Apr 20, 2026
R
2003 Mercury 200hp Saltwater edition 2 cycle, can the oiler be deleted?
I stated that there is no ECU on the motor.----Motor starts /runs on the mix ratio that is in the carburetors!
Apr 20, 2026
Dukedog
tamatoes, tamotoes.... off course it gonna start with what evers in it.... tha ecu has absolutely nothin' ta do with tha oiler...
Apr 20, 2026
legalfee
Need help finding tachometer
Check this document:
Apr 20, 2026
T
tphoyt
Anyone have any experience selling items on Vinted?
My daughter does well on poshmark
Apr 20, 2026
Since you did not have cooling water flowing to the motor when you ran it, you burned all the rubber bits in your exhaust the white...
Apr 20, 2026
S
seaflea12
reacted to
piperjoe's post
in the thread
1973 Starcraft SuperSport 16ft. restoration questions
with
Like
First off, I want to thank each of you for caring and showing you care via the “Like” placed on various posts within this thread. I am...
Apr 20, 2026
aspeck
reacted to
WIMUSKY's post
in the thread
Just thought I'd share a nice photo.
with
Like
Had one the other day. They're excellent! Very mild, fantastic table-fare. The locals concurred....
Apr 20, 2026
aspeck
Nope
Apr 20, 2026
A
affa
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
Hi, I started the engine without the drive installed to heat up the oil before changing it, it come some water out in the exhaust and it...
Apr 20, 2026
