C
COguy15
reacted to
robjq5i's post
in the thread
DF140 vst
with
Like
Follow up. Had some time and parts this weekend so here is the report. Nothing looked to terrible except the scaling on the o-ring of...
Apr 20, 2026
A
affa
replied to the thread
Mercruiser 5 L mpi cooling system
Ok thanks, I’ll check them
Apr 20, 2026
Not so sad boater
No spark 55 HP Evinrude triumph 1969
Opened closed I don't care. I can't figure it out and no shop will touch it. Rather than offering advice or tests you want to talk ****...
Apr 20, 2026
M
Mc Tool
Well I learnt something ....I never would have expected the ignition to fire when the points close . That would have had held me up for...
Apr 20, 2026
M
Mc Tool
daily music fix
https://share.google/L2WsD2JG9IfFHWmCf
Apr 20, 2026
Not so sad boater
Okay so I went ahead and swapped the distributor back out with the old one and the problem got even worse I get a flash on my timing...
Apr 20, 2026
M
Mc Tool
daily music fix
https://share.google/LhOdBltLCnJnjofMD
Apr 20, 2026
M
Mc Tool
reacted to
redneck joe's post
in the thread
daily music fix
with
Like
There are a few songs that when I hear them I can feel by body change. Wife says she can see it when I get in the boat as we pull away...
Apr 20, 2026
J
jlh3rd
Need help finding tachometer
I can't tell what #of pins in your plug end. Various cables out there. Grey is a tach wire. Maybe 5 wires?...pins? so, yes, you need a...
Apr 20, 2026
Dukedog
2003 Mercury 200hp Saltwater edition 2 cycle, can the oiler be deleted?
injection.... bleed is removing puddling/excess fuel... mostly at idle and/or lower rpm.
Apr 20, 2026
Dukedog
boy! you cats are strange.............................. "fence post anyone?"
Apr 20, 2026
B
boscoe99
Apr 20, 2026
C
Crosbyman
if you have learned more than AI that is progress. I suggest you link up with chatgpt and being specific about the 69 55HP mdl yoy have...
Apr 20, 2026
B
boscoe99
Which depends upon the amount of oil that has been injected into the gasoline supply by the variable output oil pump.
Apr 20, 2026
B
boscoe99
Like underwear for old folks, it depends. If the motor has been idling prior to shut down then the ratio of oil would have been 100/1...
Apr 20, 2026
