M
muc
replied to the thread
Merc 250 Verado Fuel increase
What does the battery test report say? The 10% is a recommendation NOT a requirement! You're good as long as your batteries get to float...
Apr 21, 2026
redneck joe
daily music fix
Sun shines on Biloxi Air is filled with vapors from the sea Boy will dig a pool beside the ocean He sees creatures from his dream...
Apr 21, 2026
bajaman123
Stoked
lol...working from home is NOT working...and is simply an abuse of the company you work for.
Apr 21, 2026
bajaman123
Hot water heater
water heater
Apr 21, 2026
Well $1700 on Bats and $200 on Charger and we'll try it again :cry: Odyssey mentions Minn Kota 3 bank 10 amps per bank
Apr 21, 2026
J
Jordankato
1988 Johnson 15 won’t stay running….
So after work today, I got home. It was the roller knob on the carb. It was screwed in too much, unscrewed that started right up stayed...
Apr 21, 2026
J
Jordankato
reacted to
jitterbug127's post
in the thread
with
Like
I ran into this last summer on a 15 i had. I'd start with checking your low speed needle on the carb. It needs to be around 1.5 turns...
Apr 21, 2026
aspeck
reacted to
redneck joe's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Or the proverbial 'hair'
Apr 21, 2026
R
Does spark jump a gap of 3/8" on both leads ?----Checked reed valves ?
Apr 21, 2026
D
Dannysmyk
reacted to
ESGWheel's post
in the thread
1981 MerCruiser 120 tick/ squeak
with
Like
Oh boy. Excessive blowby is a sign of piston rings not sealing. My new suggestion is to also do a (warm) compression test and post results.
Apr 21, 2026
J
jitterbug127
Apr 21, 2026
New SEI drive, need a new prop.
Unless you swapped to a Voyager EST distributor, you have points. The dwell and timing is an every year thing
Apr 21, 2026
D
Dannysmyk
Hi all. The season is here and finally got her out of storage. 2 cranks and fired right up. Cold compression readings prior to start...
Apr 21, 2026
R
Mercury 5 HP 4-stroke won't start
Does spark jump a gap of 3/8" (9 mm ) on a test device?
Apr 21, 2026
Lou C
Mercruiser 5 L mpi cooling system
I had to pull the outdrive to get the rest of the burned up flappers out they were in the exhaust passage, lucky the pins stayed where...
Apr 21, 2026
