C
Crosbyman
replied to the thread
Prop Rotation
don'T assume CCW rotation test to confirm
Apr 21, 2026
K
KenOverton33
posted the thread
1982 9.8HP gears issue
in
Mercury & Mariner Outboards
I am re-sealing a 1982 9.8 HP gearbox. I need to replace the reverse gear but cannot identify the gear I have. I have ordered 43-63316...
Apr 21, 2026
K
KenOverton33
Need help with ID
Thanks for the info above. Looks like a 2003
Apr 21, 2026
Merc 250 Verado Fuel increase
I found a test report where someone should fill in the blanks, but all I have is what I found in my testing. The charger bulk rate is...
Apr 21, 2026
D
DeepCMark58A
Stoked
Not when you work with your mind not your hands. My employer offered it to me so they would beg to differ too.
Apr 21, 2026
T
tphoyt
reacted to
airshot's post
in the thread
Stoked
with
Like
From someone that has been there.... Take the retirement when you can....we have no idea what the future holds !! We planned for our...
Apr 21, 2026
1981 MerCruiser 120 tick/ squeak
Your compression is low, and you are describing a washed out cam love I would pull the lifter cover and measure lifter movement with a...
Apr 21, 2026
Stoked
Not sure why you would say that. When I worked from home at a prior job during covid, I put in 65 hours a week and was 2x as efficient...
Apr 21, 2026
jimmbo
No spark 55 HP Evinrude triumph 1969
They don't last forever, just so far, I have been lucky.
Apr 21, 2026
M
muc
What does the battery test report say? The 10% is a recommendation NOT a requirement! You're good as long as your batteries get to float...
Apr 21, 2026
redneck joe
daily music fix
Sun shines on Biloxi Air is filled with vapors from the sea Boy will dig a pool beside the ocean He sees creatures from his dream...
Apr 21, 2026
bajaman123
Stoked
lol...working from home is NOT working...and is simply an abuse of the company you work for.
Apr 21, 2026
bajaman123
Hot water heater
water heater
Apr 21, 2026
Well $1700 on Bats and $200 on Charger and we'll try it again :cry: Odyssey mentions Minn Kota 3 bank 10 amps per bank
Apr 21, 2026
J
Jordankato
1988 Johnson 15 won’t stay running….
So after work today, I got home. It was the roller knob on the carb. It was screwed in too much, unscrewed that started right up stayed...
Apr 21, 2026
