CLi87
replied to the thread
What is the part number for this regulator?
Ok, I assume this is with engine running and not just key on engine off? I'll do the test hopefully tomorrow if I have time to make it...
Apr 21, 2026
Dukedog
2003 Mercury 200hp Saltwater edition 2 cycle, can the oiler be deleted?
see post #14...................
Apr 21, 2026
roscoe
reacted to
bajaman123's post
in the thread
Hot water heater
with
Like
water heater
Apr 21, 2026
F
fishbait2
reacted to
Texasmark's post
in the thread
with
Like
I have had the same type of OEM oiler on 90 and 115 HP Mercs. Only difference is the posted range for these engines is 90 at idle to 50...
Apr 21, 2026
F
fishbait2
reacted to
Dukedog's post
in the thread
with
Like
tamatoes, tamotoes.... off course it gonna start with what evers in it.... tha ecu has absolutely nothin' ta do with tha oiler...
Apr 21, 2026
F
fishbait2
reacted to
racerone's post
in the thread
with
Like
I stated that there is no ECU on the motor.----Motor starts /runs on the mix ratio that is in the carburetors!
Apr 21, 2026
F
fishbait2
reacted to
Dukedog's post
in the thread
with
Like
injection.... bleed is removing puddling/excess fuel... mostly at idle and/or lower rpm.
Apr 21, 2026
F
fishbait2
Bleed
Apr 21, 2026
F
fishbait2
reacted to
boscoe99's post
in the thread
with
Like
Like underwear for old folks, it depends. If the motor has been idling prior to shut down then the ratio of oil would have been 100/1...
Apr 21, 2026
F
fishbait2
reacted to
boscoe99's post
in the thread
with
Like
Which depends upon the amount of oil that has been injected into the gasoline supply by the variable output oil pump.
Apr 21, 2026
F
fishbait2
reacted to
boscoe99's post
in the thread
with
Like
Apr 21, 2026
R
Prop Rotation
There is no need for one to be counter rotation!!----Neither model number indicates or hints of counter rotation.
Apr 21, 2026
FLATHEAD
Stoked
Edit, don’t want to ruin the thread.
Apr 21, 2026
baconbiscut
New SEI drive, need a new prop.
Well, I went ahead and purchased the Turning Point 4 blade 17px14.5 today at my local west marine. We're about to get some data this...
Apr 21, 2026
sad boater
reacted to
jimmbo's post
in the thread
No spark 55 HP Evinrude triumph 1969
with
Like
They don't last forever, just so far, I have been lucky.
Apr 21, 2026
