replied to the thread
Boat transport
talk to the broker you are using. they will have recommendations. Make sure they are licensed and bonded. that way if things go awry...
Apr 22, 2026
J
jlh3rd
Hot water heater
read up on installation costs and requirements.
Apr 22, 2026
reacted to
Scott Danforth's post
in the thread
New SEI drive, need a new prop.
with
Like
Unless you swapped to a Voyager EST distributor, you have points. The dwell and timing is an every year thing
Apr 22, 2026
B
Boaterdan278michigan
posted the thread
Boat transport
in
Boat Topics and Questions (not engine topics)
I may need to hire a professional boat transportation company to haul a boat from Pennsylvania to Michigan. Has anyone used a company...
Apr 22, 2026
What is the part number for this regulator?
Unplugging the vacuum to the regulator is the test.
Apr 22, 2026
redneck joe
Random
The mercury man of the 70s
Apr 22, 2026
roscoe
Hot water heater
On demand heats the water at the point of use . So a heater, usually electric for convenience sake, in every room with a faucet...
Apr 22, 2026
L
LouisFeatherstone
Mobile home internet
That sounds like a solid deal, especially if you’ve been living with those older speeds. As long as it stays stable, hard to beat that...
Apr 22, 2026
C
Crosbyman
No spark 55 HP Evinrude triumph 1969
delete
Apr 21, 2026
O
omc cobra guy
Hot water heater
Apr 21, 2026
O
omc cobra guy
Hot water heater
Their not the same?
Apr 21, 2026
M
Mc Tool
Mercury 5 HP 4-stroke won't start
Stuck valve ? Stick your finger in the plug hole ,give it a pull on the starter and see if there is any compression . 2nd line original...
Apr 21, 2026
S
saltchuckmatt
Prop Rotation
With the motor off, pull the plugs, put it in gear...and turn the flywheels clockwise while observing the prop shafts. To answer your...
Apr 21, 2026
S
saltchuckmatt
1988 Johnson 15 won’t stay running….
Lots of terms I've never heard of. To answer racer question, were the parts ordered OEM? Also, there was a 10 lb difference in the...
Apr 21, 2026
8
83bluefin
1983 Blue Fin 16’ Resto
Right now I think the transom is OK. It ends above the floor and after yanking on the outboard with the tilt locked in the upright...
Apr 21, 2026
