R
robinfla52
replied to the thread
Mercury 5 HP 4-stroke won't start
I have compression. Last night when it was darker I could see bright spark in tester and on plug itself. I used a dva to measure voltage...
Apr 22, 2026
L
Lpgc
reacted to
Scott Danforth's post
in the thread
What is the part number for this regulator?
with
Like
unplug the vacuum line to the regulator. fuel pressure should spike to about 50 psi. if the fuel doesnt spike, look at the pump or the...
Apr 22, 2026
L
Lpgc
reacted to
in the thread
with
Like
Unplugging the vacuum to the regulator is the test.
Apr 22, 2026
C
Is there such a thing as peeing too hard?
the device is called a telltale, because you can see it. It does not affect cooling.
Apr 22, 2026
C
if a valve was stuck, and spark was present, the engine would backfire or catch on fire. your spark is going away under compression or...
Apr 22, 2026
L
Lpgc
I'm not too familiar with marine applications but you seem to be describing a simple mechanical fuel pressure regulator setup similar to...
Apr 22, 2026
D
DeepCMark58A
Boat transport
It is also a fun adventure to go by water, you need experience to do that though. I have gone from Pickwick TN to Florida and back a...
Apr 22, 2026
D
DeepCMark58A
Boat transport
If the boat is sitting at a marina the people there will have trusted contacts, but still trust and verify.
Apr 22, 2026
R
Boat transport
Total distance involved?----Moving it from where to where?
Apr 22, 2026
Bob_VT
reacted to
Mc Tool's post
in the thread
I’m still in the game
with
Like
I was at Macca's a while ago , they had a promo with stickers on the wrapping ,some of which were instant prizes , anyhow I wasnt...
Apr 22, 2026
redneck joe
Boat transport
And verify license and bonding. Get the papers, physically, then make calls to ensure current.
Apr 22, 2026
dingbat
reacted to
DeepCMark58A's post
in the thread
Stoked
with
Like
Well health wise thanks to the liver issues I have had I had over 50 different tests and procedures checked everything I am pretty...
Apr 22, 2026
B
Boaterdan278michigan
reacted to
in the thread
Boat transport
with
Like
talk to the broker you are using. they will have recommendations. Make sure they are licensed and bonded. that way if things go awry...
Apr 22, 2026
8.1 gx-i hitting rev limiter
Ayuh,..... At what RPMs,..??
Apr 22, 2026
D
DFWcobalt
Any ideas?
Apr 22, 2026
