J
Jordankato
posted the thread
Milky oil
in
Johnson & Evinrude Outboards
So I have a 19 8815 horse Johnson and I just went through it got all the hoses changed new gaskets and what not got a run in tuned and I...
Apr 22, 2026
replied to the thread
Boat transport
good bud of mine just had a boat moved from the east coast of Florida to Sarasota. his 3 choices were pilot around the Florida...
Apr 22, 2026
What is the part number for this regulator?
you should see 3 bar or just shy of 45 psi from the pump.
Apr 22, 2026
with only 34 psi with the vac line removed from the regulator. the regulator is fine. your pump is weak
Apr 22, 2026
L
Lpgc
I do a lot of work on fuel systems (on vehicles) but usually work in bars rather than psi or inches or water etc. If we say 1 bar is...
Apr 22, 2026
S
seacrest4
Can I Use ONE GPS/Chartplotter at TWO Helms with ONE Transducer?
You need 2 MFD units. Can be different sizes. One transducer and connect everything via NMEA 2000 and ethernet cables (video). If you...
Apr 22, 2026
matt167
Yamaha 9.9 troubles
Is $1k a fair price for one of these motors as a low hour pretty minty and mint running one?
Apr 22, 2026
CLi87
I ran the engine and pulled the vacuum line when it was at idle, fuel pressure only went up from 28psi with line connected to 34psi with...
Apr 22, 2026
S
SlipperyOar
1981 Springbok 18' Restoration/Renovation
Got some more interior work done yesterday which included adjusting the fit-up of the port console glovebox and getting the panels rough...
Apr 22, 2026
flashback
Hot water heater
Likely the existing 240v circuit, if existing heater is electric, will not be sufficient.
Apr 22, 2026
flashback
reacted to
jlh3rd's post
in the thread
Hot water heater
with
Like
read up on installation costs and requirements.
Apr 22, 2026
R
Is there such a thing as peeing too hard?
What is the water pressure on that hose?-----Test it on the lake I say.
Apr 22, 2026
R
Mercury 5 HP 4-stroke won't start
You have no spark or spark at the wrong time !!!!
Apr 22, 2026
C
there are rare cases where the spark plug is broken, or doesn't make a good ground to the head. make sure both are clean
Apr 22, 2026
R
robinfla52
Anybody think I should take to a professional. I might still be able to make some money from it if I get it running. Only have $200 invested
Apr 22, 2026
