D
DeepCMark58A
reacted to
Scott Danforth's post
in the thread
Boat transport
with
Like
good bud of mine just had a boat moved from the east coast of Florida to Sarasota. his 3 choices were pilot around the Florida...
Apr 22, 2026
R
replied to the thread
Yamaha 9.9 troubles
Some 9.9 /15 HP motors may have been leased by fishing lodges.---Returned to factory for a new hood and cosmetic touch up.-----Sold at...
Apr 22, 2026
D
DFWcobalt
8.1 gx-i hitting rev limiter
Wide open. Around 4500
Apr 22, 2026
A
airshot
Is there such a thing as peeing too hard?
If you can pee out a good 5' stream....you da man !!
Apr 22, 2026
1lastweekend
MC-1 outdrive shifter alignment questions...
Here are some pics to illustrate what I am dealing with...Shifter is in full FWD position, I have loosened the outdrive and pulled it...
Apr 22, 2026
J
Jordankato
1988 Johnson 15 won’t stay running….
I’m curious as to the terms you’ve never heard of because I’m using the terms that come straight off the diagrams.
Apr 22, 2026
J
Jordankato
posted the thread
Milky oil
in
Johnson & Evinrude Outboards
So I have a 19 8815 horse Johnson and I just went through it got all the hoses changed new gaskets and what not got a run in tuned and I...
Apr 22, 2026
Boat transport
Apr 22, 2026
What is the part number for this regulator?
you should see 3 bar or just shy of 45 psi from the pump.
Apr 22, 2026
with only 34 psi with the vac line removed from the regulator. the regulator is fine. your pump is weak
Apr 22, 2026
L
Lpgc
I do a lot of work on fuel systems (on vehicles) but usually work in bars rather than psi or inches or water etc. If we say 1 bar is...
Apr 22, 2026
S
seacrest4
Can I Use ONE GPS/Chartplotter at TWO Helms with ONE Transducer?
You need 2 MFD units. Can be different sizes. One transducer and connect everything via NMEA 2000 and ethernet cables (video). If you...
Apr 22, 2026
matt167
Yamaha 9.9 troubles
Is $1k a fair price for one of these motors as a low hour pretty minty and mint running one?
Apr 22, 2026
CLi87
I ran the engine and pulled the vacuum line when it was at idle, fuel pressure only went up from 28psi with line connected to 34psi with...
Apr 22, 2026
S
SlipperyOar
1981 Springbok 18' Restoration/Renovation
Got some more interior work done yesterday which included adjusting the fit-up of the port console glovebox and getting the panels rough...
Apr 22, 2026
