D
DeepCMark58A
replied to the thread
Blessed
Question being 59 and SS in the future, if I take it early it will screw up my taxes because Minnesota taxes SS. If I wait till 70 I...
Apr 22, 2026
L
Lpgc
What is the part number for this regulator?
Worth either putting positive pressure on the vac line to the regulator or clamping the fuel return pipe from the reg back to the tank...
Apr 22, 2026
J
jlh3rd
reacted to
flashback's post
in the thread
Hot water heater
with
Like
Likely the existing 240v circuit, if existing heater is electric, will not be sufficient.
Apr 22, 2026
1lastweekend
MC-1 outdrive shifter alignment questions...
Ok I figured it out...By adjusting the trunnion, I was able to get the upper shift shoe straight...Fit like a glove now! I will do...
Apr 22, 2026
8.1 gx-i hitting rev limiter
perfect pass is used for bad drivers in ski boats that cant watch a tach, speedo, and the wake. its intended to control the throttle to...
Apr 22, 2026
Don't really know what a perfect pass servo is on a Mechanical TB
Apr 22, 2026
aspeck
Is there such a thing as peeing too hard?
I gotta agree ... that sounds like bragging to me!
Apr 22, 2026
D
DeepCMark58A
Stripped drain plug
Recommending Silicone? Come on man.:(
Apr 22, 2026
D
DeepCMark58A
reacted to
Mc Tool's post
in the thread
Stripped drain plug
with
Like
How about something like this 😀
Apr 22, 2026
D
DeepCMark58A
reacted to
Scott Danforth's post
in the thread
Boat transport
with
Like
good bud of mine just had a boat moved from the east coast of Florida to Sarasota. his 3 choices were pilot around the Florida...
Apr 22, 2026
R
Yamaha 9.9 troubles
Some 9.9 /15 HP motors may have been leased by fishing lodges.---Returned to factory for a new hood and cosmetic touch up.-----Sold at...
Apr 22, 2026
D
DFWcobalt
Wide open. Around 4500
Apr 22, 2026
A
airshot
If you can pee out a good 5' stream....you da man !!
Apr 22, 2026
1lastweekend
Here are some pics to illustrate what I am dealing with...Shifter is in full FWD position, I have loosened the outdrive and pulled it...
Apr 22, 2026
J
Jordankato
1988 Johnson 15 won’t stay running….
I’m curious as to the terms you’ve never heard of because I’m using the terms that come straight off the diagrams.
Apr 22, 2026
