C
Crosbyman
replied to the thread
2003 Johnson 150 throttle
is this a new "Spring start up" problem ??? or a new to you boat ??? disconnect the cables at the engine are they stiff on...
Apr 22, 2026
C
Crosbyman
1988 Johnson 15 won’t stay running….
roller knob = cam follower
Apr 22, 2026
C
Crosbyman
Milky oil
Sometimes water ingress is caused by reusing old nylon bolt seals. Sometimes some oils emulsify and look bad but that is their...
Apr 22, 2026
eggs712
reacted to
SlipperyOar's post
in the thread
1981 Springbok 18' Restoration/Renovation
with
Like
Got some more interior work done yesterday which included adjusting the fit-up of the port console glovebox and getting the panels rough...
Apr 22, 2026
S
solitude
posted the thread
in
Johnson & Evinrude Outboards
I'm having an issue with a stiff throttle lever/cable/linkage or something. But when I took it for its service I mentioned I probably...
Apr 22, 2026
J
jason stu
Suzuki df200ap 2021 outboard thermostat
yes - just way more corrosion then in past years, usually average 70 hours and they look good when being replaced-
Apr 22, 2026
D
DeepCMark58A
Blessed
Question being 59 and SS in the future, if I take it early it will screw up my taxes because Minnesota taxes SS. If I wait till 70 I...
Apr 22, 2026
L
Lpgc
What is the part number for this regulator?
Worth either putting positive pressure on the vac line to the regulator or clamping the fuel return pipe from the reg back to the tank...
Apr 22, 2026
J
jlh3rd
reacted to
flashback's post
in the thread
Hot water heater
with
Like
Likely the existing 240v circuit, if existing heater is electric, will not be sufficient.
Apr 22, 2026
1lastweekend
MC-1 outdrive shifter alignment questions...
Ok I figured it out...By adjusting the trunnion, I was able to get the upper shift shoe straight...Fit like a glove now! I will do...
Apr 22, 2026
8.1 gx-i hitting rev limiter
perfect pass is used for bad drivers in ski boats that cant watch a tach, speedo, and the wake. its intended to control the throttle to...
Apr 22, 2026
Don't really know what a perfect pass servo is on a Mechanical TB
Apr 22, 2026
aspeck
Is there such a thing as peeing too hard?
I gotta agree ... that sounds like bragging to me!
Apr 22, 2026
D
DeepCMark58A
Stripped drain plug
Recommending Silicone? Come on man.:(
Apr 22, 2026
D
DeepCMark58A
reacted to
Mc Tool's post
in the thread
Stripped drain plug
with
Like
How about something like this 😀
Apr 22, 2026
