D
DeepCMark58A
replied to the thread
Blessed
Nope never mind won't work, I love it when the government tells me I make too much money. (sarcasm)
Apr 22, 2026
C
Chuck4741444
Prop Rotation
I spoke with the previous owner about getting my titles.He says one of them is counter rotation. Thanks, I will do more research, im...
Apr 22, 2026
B
boscoe99
Yamaha 9.9 troubles
Yams are not the best pissers known to man. What are using to determine a good **** from a not so good ****? If the motor is not...
Apr 22, 2026
B
boscoe99
reacted to
99yam40's post
in the thread
Yamaha 9.9 troubles
with
Like
compression is easy to check, and a carb clean & pulling stat and flushing the cooling system with something like Ridlym marine descaler...
Apr 22, 2026
B
Bhuie
99 Volvo 5.0GL
Replaced distributor cap and rotor. No change. Moving to coil replacement. If this doesn’t fix I’ll pull the Holley carb and rebuild.
Apr 22, 2026
9
99yam40
Suzuki df200ap 2021 outboard thermostat
and still you have not answered my question about if the motor is running to heat things up to open the stat while you are flushing with...
Apr 22, 2026
What is the part number for this regulator?
the VP regulator is a GM variant of the ones used in 2001-2008 in trucks. its just a slightly higher pressure version.
Apr 22, 2026
reacted to
DeepCMark58A's post
in the thread
Stripped drain plug
with
Like
Recommending Silicone? Come on man.:(
Apr 22, 2026
D
DFWcobalt
reacted to
Scott Danforth's post
in the thread
8.1 gx-i hitting rev limiter
with
Like
perfect pass is used for bad drivers in ski boats that cant watch a tach, speedo, and the wake. its intended to control the throttle to...
Apr 22, 2026
C
Crosbyman
2003 Johnson 150 throttle
is this a new "Spring start up" problem ??? or a new to you boat ??? disconnect the cables at the engine are they stiff on...
Apr 22, 2026
C
Crosbyman
1988 Johnson 15 won’t stay running….
roller knob = cam follower
Apr 22, 2026
C
Crosbyman
Milky oil
Sometimes water ingress is caused by reusing old nylon bolt seals. Sometimes some oils emulsify and look bad but that is their...
Apr 22, 2026
eggs712
reacted to
SlipperyOar's post
in the thread
1981 Springbok 18' Restoration/Renovation
with
Like
Got some more interior work done yesterday which included adjusting the fit-up of the port console glovebox and getting the panels rough...
Apr 22, 2026
S
solitude
posted the thread
in
Johnson & Evinrude Outboards
I'm having an issue with a stiff throttle lever/cable/linkage or something. But when I took it for its service I mentioned I probably...
Apr 22, 2026
J
jason stu
yes - just way more corrosion then in past years, usually average 70 hours and they look good when being replaced-
Apr 22, 2026
