A
airshot
reacted to
DeepCMark58A's post
in the thread
Blessed
with
Like
Question being 59 and SS in the future, if I take it early it will screw up my taxes because Minnesota taxes SS. If I wait till 70 I...
Apr 22, 2026
A
airshot
replied to the thread
New SEI drive, need a new prop.
Tune up the motor thoroughly by fire getting test numbers or you might be doing it all over.
Apr 22, 2026
A
airshot
reacted to
Scott Danforth's post
in the thread
with
Like
I would file the points, set the dwell and timing and do a tune up to see if the RPM's come back.
Apr 22, 2026
A
airshot
Stripped drain plug
Yep, gotta agree, no silicone on anything outdoors....
Apr 22, 2026
A
airshot
reacted to
aspeck's post
in the thread
Is there such a thing as peeing too hard?
with
Like
I gotta agree ... that sounds like bragging to me!
Apr 22, 2026
R
Milky oil
The shift rod is exposed there.----Very normal.-----There is a seal on the shift rod , but nowhere near that exposed part.-----Did you...
Apr 22, 2026
D
DeepCMark58A
Blessed
Nope never mind won't work, I love it when the government tells me I make too much money. (sarcasm)
Apr 22, 2026
C
Chuck4741444
Prop Rotation
I spoke with the previous owner about getting my titles.He says one of them is counter rotation. Thanks, I will do more research, im...
Apr 22, 2026
B
boscoe99
Yamaha 9.9 troubles
Yams are not the best pissers known to man. What are using to determine a good **** from a not so good ****? If the motor is not...
Apr 22, 2026
B
boscoe99
reacted to
99yam40's post
in the thread
Yamaha 9.9 troubles
with
Like
compression is easy to check, and a carb clean & pulling stat and flushing the cooling system with something like Ridlym marine descaler...
Apr 22, 2026
B
Bhuie
99 Volvo 5.0GL
Replaced distributor cap and rotor. No change. Moving to coil replacement. If this doesn’t fix I’ll pull the Holley carb and rebuild.
Apr 22, 2026
9
99yam40
Suzuki df200ap 2021 outboard thermostat
and still you have not answered my question about if the motor is running to heat things up to open the stat while you are flushing with...
Apr 22, 2026
What is the part number for this regulator?
the VP regulator is a GM variant of the ones used in 2001-2008 in trucks. its just a slightly higher pressure version.
Apr 22, 2026
reacted to
DeepCMark58A's post
in the thread
Stripped drain plug
with
Like
Recommending Silicone? Come on man.:(
Apr 22, 2026
D
DFWcobalt
reacted to
in the thread
8.1 gx-i hitting rev limiter
with
Like
perfect pass is used for bad drivers in ski boats that cant watch a tach, speedo, and the wake. its intended to control the throttle to...
Apr 22, 2026
