S
saltchuckmatt
replied to the thread
Prop Rotation
Lol, nobody seems to want to answer your question...you pull it forward to get it in gear. Cheers
Apr 22, 2026
C
Crosbyman
Prop Rotation
most likely a C https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1996&hp=200&model=BJ200CXEDR
Apr 22, 2026
jimmbo
Oil 4 stroke Mercury 115hp
Welcome to iboats Mercury markets several Oils for your engine. Can't go wrong with them, especially during the Warranty Period. As...
Apr 22, 2026
M
Mc Tool
Cracked bearing carrier, run or replace?
When I removed mine I had to clean a lot of crud and corrosion off both the bearing carrier and the inside of the lower unit. I...
Apr 22, 2026
jimmbo
What Engine is that? What(else) did you remove and reinstall? In the pics, I see the Propshaft, Reverse Gear...
Apr 22, 2026
C
Chuck4741444
Prop Rotation
I spoke with the previous owner about getting my titles.He says one of them is counter rotation. Thanks, I will do more research, im...
Apr 22, 2026
H
highpowerdad
posted the thread
Rear main seal on 5.7 GXI
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
So... pulled the coupler off - the one that was bent - and while I was there, I figured I might as well pull the flywheel off and look...
Apr 22, 2026
A
aidanmurphy
posted the thread
in
Mercury & Mariner Outboards
Cracked my bearing carrier putting it back onto the lower after pressing in the new prop shaft seals. Ordering a new carrier but any...
Apr 22, 2026
CLi87
What is the part number for this regulator?
I just bought a new fuel pump and it should be here Saturday so I'll install it and hopefully that fixes my problem, thanks!
Apr 22, 2026
CLi87
Thanks! I'll definitely get one of those, can't believe they want over $500 for the OEM Mercruiser one, why is that one so much more...
Apr 22, 2026
R
Prop Rotation
And here I thought the letter----N----was for counter rotation in the 96 model year.
Apr 22, 2026
M
Mc Tool
reacted to
redneck joe's post
in the thread
Random
with
Like
Only minus 3? Tis but a flesh wound....
Apr 22, 2026
Kla
2002 Four Winns 214 Funship
I've checked Great Lakes Skipper already but haven't found one that matches up. Never thought of RV sites. Will definitely check some...
Apr 22, 2026
matt167
Yamaha 9.9 troubles
The one I have just has many signs of being a worn out high hour motor when you look close. I missed it when I bought it truthfully as...
Apr 22, 2026
M
Mc Tool
Mercury 5 HP 4-stroke won't start
Yep ,if one of them is stuck it will have way to much valve clearance .....but if you do have compression they aint stuck . Usually its...
Apr 22, 2026
