replied to the thread
Support for new floor
2# is more than enough
Apr 23, 2026
redneck joe
reacted to
Mc Tool's post
in the thread
Random
with
Like
🤣🤣Put a mustache on it and it would look like your avatar Joe 😂😂😂
Apr 23, 2026
M
Mc Tool
Random
Apr 23, 2026
redneck joe
Random
Apr 23, 2026
R
Cracked bearing carrier, run or replace?
What motor?----Did you turn the motor when tightening those bolts?----Do not run it the way it is now.
Apr 23, 2026
R
Milky oil
Did you turn the propeller when shifting on the stand ?
Apr 23, 2026
G
gmach
95 Sea Ray 230 Sundancer stringer repair
The transom core is now bonded to the boat. I mixed up about 6 quarts of thickened epoxy resin to spread it on. I ended up throwing away...
Apr 22, 2026
S
saltchuckmatt
Milky oil
Looks like some of that lower price greenish oil that I've seen. Video was quick and hard to see clearly. Might not be bad at all. Like...
Apr 22, 2026
S
saltchuckmatt
Prop Rotation
Hey Crosbyman....does chat gpt do all that or do you lay out all that stuff?
Apr 22, 2026
S
saltchuckmatt
Prop Rotation
Lol, nobody seems to want to answer your question...you pull it forward to get it in gear. Cheers
Apr 22, 2026
C
Crosbyman
Prop Rotation
most likely a C https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1996&hp=200&model=BJ200CXEDR
Apr 22, 2026
jimmbo
Oil 4 stroke Mercury 115hp
Welcome to iboats Mercury markets several Oils for your engine. Can't go wrong with them, especially during the Warranty Period. As...
Apr 22, 2026
M
Mc Tool
When I removed mine I had to clean a lot of crud and corrosion off both the bearing carrier and the inside of the lower unit. I...
Apr 22, 2026
jimmbo
What Engine is that? What(else) did you remove and reinstall? In the pics, I see the Propshaft, Reverse Gear...
Apr 22, 2026
C
Chuck4741444
Prop Rotation
I spoke with the previous owner about getting my titles.He says one of them is counter rotation. Thanks, I will do more research, im...
Apr 22, 2026
