L
Lpgc
replied to the thread
What is the part number for this regulator?
If a fuel pressure damper goes wrong there are usually no symptoms unless it leaks.
Apr 23, 2026
L
Lpgc
reacted to
Fun Times's post
in the thread
with
Like
Because there are two of them for the marine version the regulator you found on top of the engine is more so considered to be a fuel...
Apr 23, 2026
L
Lpgc
reacted to
Scott Danforth's post
in the thread
with
Like
the VP regulator is a GM variant of the ones used in 2001-2008 in trucks. its just a slightly higher pressure version.
Apr 23, 2026
C
Chuck4741444
Motor support racks
until i sell them or part them out You right, I have to much to loss if it fell overail
Apr 23, 2026
C
Chuck4741444
reacted to
Crosbyman's post
in the thread
Prop Rotation
with
Like
it is simple 96 johnson 200 Model # j200txedr & # j2000xedr You’ve got two model numbers there, but one of them is likely a...
Apr 23, 2026
R
Oil 4 stroke Mercury 115hp
Motors are too expensive to skimp on oil.-----Use the factory recommended product.
Apr 23, 2026
Support for new floor
2# is more than enough
Apr 23, 2026
redneck joe
reacted to
Mc Tool's post
in the thread
Random
with
Like
🤣🤣Put a mustache on it and it would look like your avatar Joe 😂😂😂
Apr 23, 2026
M
Mc Tool
Random
Apr 23, 2026
redneck joe
Random
Apr 23, 2026
R
Cracked bearing carrier, run or replace?
What motor?----Did you turn the motor when tightening those bolts?----Do not run it the way it is now.
Apr 23, 2026
R
Milky oil
Did you turn the propeller when shifting on the stand ?
Apr 23, 2026
G
gmach
95 Sea Ray 230 Sundancer stringer repair
The transom core is now bonded to the boat. I mixed up about 6 quarts of thickened epoxy resin to spread it on. I ended up throwing away...
Apr 22, 2026
S
saltchuckmatt
Milky oil
Looks like some of that lower price greenish oil that I've seen. Video was quick and hard to see clearly. Might not be bad at all. Like...
Apr 22, 2026
S
saltchuckmatt
Prop Rotation
Hey Crosbyman....does chat gpt do all that or do you lay out all that stuff?
Apr 22, 2026
