reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
The sun is shining so I'm doing some more glassing. I did the crossbar pieces over the past couple of days, and today I glassed the...
Apr 23, 2026
FLATHEAD
reacted to
tpenfield's post
in the thread
with
Like
Apr 23, 2026
tpenfield
replied to the thread
Apr 23, 2026
D
Dannysmyk
1981 MerCruiser 120 tick/ squeak
i just looked into that rocker more. The push rod for that one is bent. Coulld this be the cause of the issue or a result from bad lifter?
Apr 23, 2026
matt167
Yamaha 9.9 troubles
I’m going to go for it. I really wanted another 4 stroke FI Suzuki but it’s not in the cards this year with the boat purchase and it...
Apr 23, 2026
S
SlipperyOar
reacted to
legalfee's post
in the thread
Need help finding tachometer
with
Like
Check this document:
Apr 23, 2026
S
SlipperyOar
reacted to
legalfee's post
in the thread
with
Like
Wiring is illustrated on the PDF I attached. Gray wire to Send. Purple wire (switched 12 volts) to IGN. And Black wire to GND.
Apr 23, 2026
M
MikeSchinlaub
reacted to
DeepCMark58A's post
in the thread
Boat transport
with
Like
You can't own a boat and worry about fuel cost>:ROFLMAO:
Apr 23, 2026
S
saltchuckmatt
Prop Rotation
Apr 23, 2026
A
airshot
1983 Blue Fin 16’ Resto
This boat is a 1983, some 45 years old. The wood in the transom was never sealed at the factory, so.....if you created a good plywood...
Apr 23, 2026
R
Mercury 5 HP 4-stroke won't start
Report the valve clearance that you found.----If motor does not pop with fuel in the cylinder you have no spark or spark at the wrong...
Apr 23, 2026
C
Crabeye
1982 starcraft v220 mariner v5 potential rebuild
UPDATE!!!! I Have boat floor of,stripped of foam,ready to rebuild and just acquired 21 ft Duckworth turnkey..Have decided to sell...So...
Apr 23, 2026
R
2003 Johnson 150 throttle
Remove cables at the motor.----Operate linkages and see how they move.----Perhaps lubricate them.-----Picture of your controls...
Apr 23, 2026
M
Mark R.
Alpha One Gen 2 Shaft Seal Choice
Hey, thank you for the reply to my question. The seal I'm referring to is actually #5 in this assembly drawing...
Apr 23, 2026
S
solitude
Yep. Just confused by it not feeling good for me but the mechanic said it's working fine. And hasn't changed since I got the boat
Apr 23, 2026
