P
Pmt133
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
The sun is shining so I'm doing some more glassing. I did the crossbar pieces over the past couple of days, and today I glassed the...
Apr 23, 2026
redneck joe
replied to the thread
daily music fix
Thats new as well, but I do have to say the early 90s were pretty good. Still coming off the (literal) cocaine of the 80s and not...
Apr 23, 2026
reacted to
Scott Danforth's post
in the thread
1981 MerCruiser 120 tick/ squeak
with
Like
could be, however most likely the exhaust riser gasket is leaking and the valve is rusted
Apr 23, 2026
Alpha One Gen 2 Shaft Seal Choice
Not real familiar with the Alpha like I am the Bravo. The Bravo changed from 2 seals to a double seal and I installed the new double...
Apr 23, 2026
M
Mc Tool
daily music fix
https://share.google/QX5ToLHFe0SlPPmx1
Apr 23, 2026
Apr 23, 2026
reacted to
tpenfield's post
in the thread
with
Like
Apr 23, 2026
FLATHEAD
reacted to
tpenfield's post
in the thread
with
Like
Apr 23, 2026
tpenfield
Apr 23, 2026
D
Dannysmyk
i just looked into that rocker more. The push rod for that one is bent. Coulld this be the cause of the issue or a result from bad lifter?
Apr 23, 2026
matt167
Yamaha 9.9 troubles
I’m going to go for it. I really wanted another 4 stroke FI Suzuki but it’s not in the cards this year with the boat purchase and it...
Apr 23, 2026
S
SlipperyOar
reacted to
legalfee's post
in the thread
Need help finding tachometer
with
Like
Check this document:
Apr 23, 2026
S
SlipperyOar
reacted to
legalfee's post
in the thread
with
Like
Wiring is illustrated on the PDF I attached. Gray wire to Send. Purple wire (switched 12 volts) to IGN. And Black wire to GND.
Apr 23, 2026
M
MikeSchinlaub
reacted to
DeepCMark58A's post
in the thread
Boat transport
with
Like
You can't own a boat and worry about fuel cost>:ROFLMAO:
Apr 23, 2026
S
saltchuckmatt
Prop Rotation
Apr 23, 2026
