Sprig
replied to the thread
18ft Boat Launch with RWD Suburban
A large percentage of people launch and retrieve with 2wd’s all the time. As said it all depends on what the launch ramp is like . You...
Apr 24, 2026
Lou C
Rear main seal on 5.7 GXI
Hard to say, the front and rear seals on my old 4.3 which has to have at least 1500 if not more hrs on it, don't leak, but on the other...
Apr 24, 2026
Clean the bilge and make sure the pump works
Apr 24, 2026
H
highpowerdad
Would a leaking rear seal be expected with 450 hours? I guess it is 20 years old… what else should I be looking at before the motor...
Apr 24, 2026
Lou C
99 Volvo 5.0GL
The gas that gave me fits last season, was only 8/9 months old, stabilized E10 (all we can get at the gas docks here) and looked totally...
Apr 24, 2026
Lou C
Mercruiser 5 L mpi cooling system
It's impossible to generalize because every boat is different, some have more than enough static water line height, some are marginal...
Apr 24, 2026
flashback
I/O (Sterndrive) Conversion to Outboards
Removable teak grates for the floor would be nice, give it a bit of a nautical look.
Apr 24, 2026
Ifishmuskie2
Here’s my plan B as I have front wheel drive pulling 2400lb total. If it won’t pull it out unhook the boat and trailer. Then drive...
Apr 24, 2026
tpenfield
The center stringer support is done. I do plan on putting in a floor of some sort to make for a decent storage area. The new stringer...
Apr 24, 2026
flashback
I've launched with 2wd all my life. As noted above, its all about the ramp.
Apr 24, 2026
J
jlh3rd
That's true. I do tow/launch my 24' pontoon with my '08 extended cab, long bed, 5.3, Silverado 2WD ( Posi). I haven't been to a lot of...
Apr 24, 2026
flashback
reacted to
Lpgc's post
in the thread
with
Like
I expect some will say it depends on what the slipway is like, how steep it is, is it wet / slippy / etc..
Apr 24, 2026
tpenfield
reacted to
Scott Danforth's post
in the thread
with
Like
Ted, will you be adding shelving to hold the beer er provisionings in the old bilge area? if you need a design for a service elevator...
Apr 24, 2026
tpenfield
reacted to
redneck joe's post
in the thread
with
Like
Forgot you were in Yankee weather....
Apr 24, 2026
L
Lpgc
Apr 24, 2026
