replied to the thread
18ft Boat Launch with RWD Suburban
4 wheel drive is required on slimey ramps and if you have to back in to the front axle 2WD is fine 98% of the time
Apr 24, 2026
Rear main seal on 5.7 GXI
GM has trucks failing with front oil seals leaking on the lots and under a year. It's man made, if it's leaking, replace it
Apr 24, 2026
reacted to
Lou C's post
in the thread
Mercruiser 5 L mpi cooling system
with
Like
It's impossible to generalize because every boat is different, some have more than enough static water line height, some are marginal...
Apr 24, 2026
B
Bhuie
99 Volvo 5.0GL
HEY GUYS…COIL FIXED IT!!! Thank you all for the advice!!
Apr 24, 2026
jimmbo
I launched on this more than once with using a Car with the Boat and Trailer weighing in at 3500lb. Never had any issues
Apr 24, 2026
J
Jeff J
Crazy Strange with my primer bulb
I will try to remember to try that the next time I have one to remove. I don’t like what it takes to get them off the hose even after I...
Apr 24, 2026
Sprig
A large percentage of people launch and retrieve with 2wd’s all the time. As said it all depends on what the launch ramp is like . You...
Apr 24, 2026
Lou C
Hard to say, the front and rear seals on my old 4.3 which has to have at least 1500 if not more hrs on it, don't leak, but on the other...
Apr 24, 2026
Clean the bilge and make sure the pump works
Apr 24, 2026
H
highpowerdad
Would a leaking rear seal be expected with 450 hours? I guess it is 20 years old… what else should I be looking at before the motor...
Apr 24, 2026
Lou C
99 Volvo 5.0GL
The gas that gave me fits last season, was only 8/9 months old, stabilized E10 (all we can get at the gas docks here) and looked totally...
Apr 24, 2026
Lou C
Apr 24, 2026
flashback
I/O (Sterndrive) Conversion to Outboards
Removable teak grates for the floor would be nice, give it a bit of a nautical look.
Apr 24, 2026
Ifishmuskie2
Here’s my plan B as I have front wheel drive pulling 2400lb total. If it won’t pull it out unhook the boat and trailer. Then drive...
Apr 24, 2026
tpenfield
The center stringer support is done. I do plan on putting in a floor of some sort to make for a decent storage area. The new stringer...
Apr 24, 2026
