tpenfield
replied to the thread
I/O (Sterndrive) Conversion to Outboards
Installation Update . . . I got the extension bracket aligned with the different (0.45") spacers. As such, I drilled the 'pilot' holes...
Apr 24, 2026
bajaman123
reacted to
Lpgc's post
in the thread
18ft Boat Launch with RWD Suburban
with
Like
I expect some will say it depends on what the slipway is like, how steep it is, is it wet / slippy / etc..
Apr 24, 2026
Lou C
buying a new boat, this is broken on the trailer. what is it?
That's what it looks like. I have the same thing.....flush system for drum brakes that trailer looks like it might need some work...
Apr 24, 2026
Lou C
99 Volvo 5.0GL
thanks for the follow up! Just filled up my boat with Sunoco 94 octane for its trial run next week....
Apr 24, 2026
Lou C
reacted to
Bhuie's post
in the thread
99 Volvo 5.0GL
with
Like
HEY GUYS…COIL FIXED IT!!! Thank you all for the advice!!
Apr 24, 2026
reacted to
Lpgc's post
in the thread
with
Like
Apr 24, 2026
B
Boaterdan278michigan
reacted to
DeepCMark58A's post
in the thread
Boat transport
with
Like
It is also a fun adventure to go by water, you need experience to do that though. I have gone from Pickwick TN to Florida and back a...
Apr 24, 2026
M
Mc Tool
Done it before, my Dad had a "flying fifteen" yacht that needed a good 5 feet of water to float so using the above method was mandatory...
Apr 24, 2026
M
Mc Tool
reacted to
Ifishmuskie2's post
in the thread
with
Like
Here’s my plan B as I have front wheel drive pulling 2400lb total. If it won’t pull it out unhook the boat and trailer. Then drive...
Apr 24, 2026
4 wheel drive is required on slimey ramps and if you have to back in to the front axle 2WD is fine 98% of the time
Apr 24, 2026
Rear main seal on 5.7 GXI
GM has trucks failing with front oil seals leaking on the lots and under a year. It's man made, if it's leaking, replace it
Apr 24, 2026
reacted to
Lou C's post
in the thread
Mercruiser 5 L mpi cooling system
with
Like
It's impossible to generalize because every boat is different, some have more than enough static water line height, some are marginal...
Apr 24, 2026
B
Bhuie
99 Volvo 5.0GL
Apr 24, 2026
jimmbo
I launched on this more than once with using a Car with the Boat and Trailer weighing in at 3500lb. Never had any issues
Apr 24, 2026
J
Jeff J
Crazy Strange with my primer bulb
I will try to remember to try that the next time I have one to remove. I don’t like what it takes to get them off the hose even after I...
Apr 24, 2026
