Lou C
reacted to
Bondo's post
in the thread
Starter stays running.
with
Like
Ayuh,..... at the switch, the yellow/ red wire should be powered Only when the key is in the Start position,.....
Apr 25, 2026
T
tphoyt
reacted to
FLATHEAD's post
in the thread
There almost here
with
Like
Good luck on them. 😎They are in the Delaware River for a couple weeks now. A friend has been after them in bucks county, no big ones in...
Apr 25, 2026
L
Lpgc
reacted to
Toddavid's post
in the thread
Power steering fluid in bilge?
with
Like
It’s easy being shiny on the outside, but what really counts is being shiny on the inside. Put another hour of run time on her and...
Apr 25, 2026
replied to the thread
On the starter solenoid are 3 connections B is Battery cable S is the start wire ( yellow with red stripe) R or I is the relay...
Apr 25, 2026
BWR1953
AI can help troubleshoot. I
Apr 25, 2026
reacted to
Bondo's post
in the thread
with
Like
Apr 25, 2026
Apr 25, 2026
P
Popeye303
posted the thread
Too Much Prop Issue?
in
Prop Questions and Topics
Tested a 2011 Tahoe Q5i with 4.3L mercruiser and 14 x 23” prop. All seemed to be good except WOT resulted in ~3300 RPM & 39 MPH. Two...
Apr 25, 2026
W
whydoihateboats
Apr 25, 2026
W
whydoihateboats
I have a test light and multi meter, just no idea where to start.
Apr 25, 2026
J
Jeff J
reacted to
Bondo's post
in the thread
with
Like
Ayuh,.... Welcome Aboard,...... The only way to answer yer question, is by Testing the start circuit,..... Get yerself a test...
Apr 25, 2026
J
jlh3rd
reacted to
KD4UPL's post
in the thread
Hot water heater
with
Like
Are you asking about electric or gas? If gas it's probably a good idea unless your water has a lot of mineral content. If electric you...
Apr 25, 2026
FLATHEAD
There almost here
Apr 25, 2026
reacted to
Bondo's post
in the thread
with
Like
Apr 25, 2026
ID needed please.
Welcome The boat was licensed at one time, do you have the title or bill of sale? Contact the state which licensed it and they should be...
Apr 25, 2026
