Simoniz
replied to the thread
4 cylinder pushrod cover replacement?
So Ive done this job, and can confirm that there is room to remove and replace the cover with the distributor in place - but only just...
Apr 25, 2026
M
Mark R.
Alpha One Gen 2 Shaft Seal Choice
The outdrive serial number is 0F709127. Along with the driveshaft seals, I plan to replace the yoke seal. So won't I need to reset the...
Apr 25, 2026
D
DeepCMark58A
18ft Boat Launch with RWD Suburban
If you have 4 wheel drive you can back in as far as you want. I have been to boat ramps in northern WI and MN where you had to have the...
Apr 25, 2026
JimS123
Rear wheels wet? I don't think so!!! Unless you have a "ramp" that is not designed right, if you can't walk behind the car to work the...
Apr 25, 2026
Hot water heater
Electric tankless water heaters have 3+ high current elements in a manifold, hence the need for a much larger electrical service
Apr 25, 2026
dingbat
Too Much Prop Issue?
Something really wrong. You’re pushing 1,200 - 1,400 rpm short of where you need to be. Too much to be a prop Engine problems, water...
Apr 25, 2026
There almost here
A bit of humor
Apr 25, 2026
dingbat
New old boat checklist.
That would be a 800 pump. A 1,000 pump is 1-1/8” if I remember correctly
Apr 25, 2026
Lou C
Starter stays running.
You can check for voltage at the yellow red wire for the starter either at the ignition switch or at the solenoid itself (switch will be...
Apr 25, 2026
Lou C
reacted to
Bondo's post
in the thread
with
Like
Ayuh,..... at the switch, the yellow/ red wire should be powered Only when the key is in the Start position,.....
Apr 25, 2026
T
tphoyt
reacted to
FLATHEAD's post
in the thread
There almost here
with
Like
Good luck on them. 😎They are in the Delaware River for a couple weeks now. A friend has been after them in bucks county, no big ones in...
Apr 25, 2026
L
Lpgc
reacted to
Toddavid's post
in the thread
Power steering fluid in bilge?
with
Like
It’s easy being shiny on the outside, but what really counts is being shiny on the inside. Put another hour of run time on her and...
Apr 25, 2026
On the starter solenoid are 3 connections B is Battery cable S is the start wire ( yellow with red stripe) R or I is the relay...
Apr 25, 2026
BWR1953
AI can help troubleshoot. I
Apr 25, 2026
reacted to
Bondo's post
in the thread
with
Like
Apr 25, 2026
