P
Popeye303
replied to the thread
Too Much Prop Issue?
Thanks for the reply. Long block and exhaust manifolds replaced and carb overhauled in Dec 2022 by a boat shop. Had maybe 20 hours on...
Apr 25, 2026
dwco5051
reacted to
Scott Danforth's post
in the thread
Hot water heater
with
Like
Electric tankless water heaters have 3+ high current elements in a manifold, hence the need for a much larger electrical service
Apr 25, 2026
dwco5051
reacted to
flashback's post
in the thread
Hot water heater
with
Like
Likely the existing 240v circuit, if existing heater is electric, will not be sufficient.
Apr 25, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Installation Update . . . I got the extension bracket aligned with the different (0.45") spacers. As such, I drilled the 'pilot' holes...
Apr 25, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
with
Like
The center stringer support is done. I do plan on putting in a floor of some sort to make for a decent storage area. The new stringer...
Apr 25, 2026
R
18ft Boat Launch with RWD Suburban
Agreed, on more than one occasion, have folks offered help to retrieve my boats.---I politely declined.----I just submerge last roller...
Apr 25, 2026
Simoniz
4 cylinder pushrod cover replacement?
So Ive done this job, and can confirm that there is room to remove and replace the cover with the distributor in place - but only just...
Apr 25, 2026
M
Mark R.
Alpha One Gen 2 Shaft Seal Choice
The outdrive serial number is 0F709127. Along with the driveshaft seals, I plan to replace the yoke seal. So won't I need to reset the...
Apr 25, 2026
D
DeepCMark58A
If you have 4 wheel drive you can back in as far as you want. I have been to boat ramps in northern WI and MN where you had to have the...
Apr 25, 2026
JimS123
Rear wheels wet? I don't think so!!! Unless you have a "ramp" that is not designed right, if you can't walk behind the car to work the...
Apr 25, 2026
Hot water heater
Apr 25, 2026
dingbat
Something really wrong. You’re pushing 1,200 - 1,400 rpm short of where you need to be. Too much to be a prop Engine problems, water...
Apr 25, 2026
There almost here
A bit of humor
Apr 25, 2026
dingbat
New old boat checklist.
That would be a 800 pump. A 1,000 pump is 1-1/8” if I remember correctly
Apr 25, 2026
Lou C
Starter stays running.
You can check for voltage at the yellow red wire for the starter either at the ignition switch or at the solenoid itself (switch will be...
Apr 25, 2026
