flashback
replied to the thread
I/O (Sterndrive) Conversion to Outboards
Won't the nuts on the pins need a recess in the transom?
Apr 25, 2026
CLi87
What is the part number for this regulator?
Just installed the new fuel pump but my pressure is still the same, running at idle it's at 28 psi and with regulator hose d/c it's at...
Apr 25, 2026
flashback
reacted to
tpenfield's post
in the thread
with
Like
Installation Update . . . I got the extension bracket aligned with the different (0.45") spacers. As such, I drilled the 'pilot' holes...
Apr 25, 2026
flashback
18ft Boat Launch with RWD Suburban
Sure looks like fun..!
Apr 25, 2026
Scott06
Alpha One Gen 2 Shaft Seal Choice
To do the seal you have to remove the outer race of the bearing above it. There is a rolling torque for the vertical gear and...
Apr 25, 2026
roscoe
Hot water heater
Went from electric to gas to cut electric bill by $70 a month. Needed high capacity for the wife's new garden soaker tub, which will...
Apr 25, 2026
T
tphoyt
Trail camera issues fixed, now pics from them ...
They did a drone survey of the island over the winter of the deer population. There are some hot spots with over 100 deer per sq mile.
Apr 25, 2026
J
jasonburba74
Mercruiser 4.3L wire harness
Not sure of the years, but the serial number for the 4.3 is 1A072140, and the 5.0 serial number is 0L639572. Neither engine is fuel...
Apr 25, 2026
D
DeepCMark58A
Hot water heater
How long did the old water heater last? Why not replace it with the same?
Apr 25, 2026
D
DeepCMark58A
I can't believe that brief exposure to salt water could be worse that the 5 months a year we drive on salt covered roads here in Minnesota.
Apr 25, 2026
Fun Times
What years are both engines and was one or both fuel injected at one point or another? any serial numbers handy?
Apr 25, 2026
matt167
New old boat checklist.
You’re probably right. It’s been a year since I’ve seen them as they are sitting in my other boat in storage
Apr 25, 2026
D
DeepCMark58A
When I worked Fire for the DNR we would stage in parts of the county, I often parked at a large county park that was on the lake. I...
Apr 25, 2026
redneck joe
I cannot say either way if they know how to back so I choose to enjoy and my enjoyment is from the people that can't back. Ive been...
Apr 25, 2026
J
jasonburba74
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
I need your help; I have a Mercruiser 4.3L engine, and I'm doing an engine swap to a 5.0L. Had the motor sitting in my garage with the...
Apr 25, 2026
