jimmbo
replied to the thread
18ft Boat Launch with RWD Suburban
That's not nice, those, illegitimates, probably couldn't launch a boat either
Apr 25, 2026
redneck joe
There are also a group of young men that set up at ramps to cheer the fails.
Apr 25, 2026
redneck joe
Especially the Miami ramp fails.
Apr 25, 2026
jimmbo
The Ramps have always been a great source of entertainment...
Apr 25, 2026
redneck joe
Hot water heater
So a base question would be why do you think you want one?
Apr 25, 2026
JimS123
I thought I had seen everything. Then, recently I happened to come across a few YouTube videos entitled "Ramp Failures". I never saw...
Apr 25, 2026
dingbat
Too Much Prop Issue?
Why does a motor with probably less than a couple hundred hours of run time need a new long block and manifolds? A prop buys you...
Apr 25, 2026
jimmbo
Told this Guy, to use the other Ramp, not this one which is only good for Canoes...
Apr 25, 2026
dingbat
Better ramps or better boaters? Nobody in their right mind would consider backing their tow vehicle into saltwater to launch. It’s...
Apr 25, 2026
R
If you are looking to buy this boat then ---" buyer beware" ---I say.
Apr 25, 2026
T
tphoyt
reacted to
Scott Danforth's post
in the thread
There almost here
with
Like
A bit of humor
Apr 25, 2026
A
airshot
Water logged foam....it can add hundreds of pounds of water soaked up by the flotation foam under the floor. How old is the boat ...
Apr 25, 2026
A
airshot
reacted to
racerone's post
in the thread
with
Like
Agreed, on more than one occasion, have folks offered help to retrieve my boats.---I politely declined.----I just submerge last roller...
Apr 25, 2026
A
airshot
You are correct, however there are ramps that are shallow or the water is low etc that does require getting the back tires in the water...
Apr 25, 2026
9
995jim
posted the thread
which order to do maintenance
in
Mercury MerCruiser Sterndrives & Engines
Hi, Its time to pull the bravo1 lower unit and grease the gimble joint and also do a lower unit oil change. any advise on which to do...
Apr 25, 2026
