R
Renken2000Classic
replied to the thread
Hot water heater
That's a good one
Apr 25, 2026
T
TXGlastron
reacted to
racerone's post
in the thread
Mercruiser 5.7L and 5.0L, help me identify a part
with
Like
Power trim / tilt pump / motor / fluid reservoir.
Apr 25, 2026
T
TXGlastron
Well, after doing YouTube research, this is the trim pump and reservoir. I am way off!
Apr 25, 2026
R
Apr 25, 2026
T
TXGlastron
(And if I am a betting man, this has to be fuel related. Those are fuel lines)
Apr 25, 2026
R
Renken2000Classic
18ft Boat Launch with RWD Suburban
5.7L (Vortec) Suburban with 3.73:1 (ltd slip) and 2WD. Works every time, but there are some ramps at my lake (one in particular) I'd be...
Apr 25, 2026
M
Mark R.
Alpha One Gen 2 Shaft Seal Choice
Engine is a 1996 Mercruiser 4.3 LX Gen+. Outdrive is an Alpha One Gen 2 (S/N: 0F709127). I am currently replacing all the seals in the...
Apr 25, 2026
T
TXGlastron
Exhaust manifold discovery?
After I posted that picture, I discovered both exhaust manifolds cracked. It was NOT winterized properly and the cracking was a direct...
Apr 25, 2026
T
TXGlastron
MerCruiser v8 350 installed, exhaust note options
I decided to not install any aftermarket exhaust. I agree cyclops222, and I don’t want to be looked at that way on the lake. No extra...
Apr 25, 2026
T
TXGlastron
2008 Glastron GXL 235, new 5.7 Mercruiser engine, bogging at 3000rpms
I know this post is old, but I want to close it out with info for others. You are definitely correct that the blower motor has nothing...
Apr 25, 2026
Fun Times
What is the part number for this regulator?
The low pressure regulator number 15 bolts down to the cooler and then one side has a fuel return hose that bolts to it/an adapter...
Apr 25, 2026
T
TXGlastron
posted the thread
in
Glastron Boats
I’d like some help identifying this part. Grok is telling me this is the Cool Fuel pump and reservoir. When I search on the internet a...
Apr 25, 2026
T
TXGlastron
Glastron GXL 235 anti siphon valve location?
I finally found it and I feel stupid. For anyone that has this question in the future, it is directly in front of the engine...
Apr 25, 2026
C
carlos515
posted the thread
Question on cap removal
in
Boat Restoration, Building, and Hull Repair
I ended up with my Sun Ray back to work on. Long story for another time. I would like to take the cap off. I have the boat off the...
Apr 25, 2026
redneck joe
reacted to
DeepCMark58A's post
in the thread
with
Like
I can't believe that brief exposure to salt water could be worse that the 5 months a year we drive on salt covered roads here in Minnesota.
Apr 25, 2026
