Texasmark
reacted to
dingbat's post
in the thread
Too Much Prop Issue?
with
Like
Why does a motor with probably less than a couple hundred hours of run time need a new long block and manifolds? A prop buys you...
Apr 25, 2026
R
replied to the thread
83 7.5hp, smoke from cowl
Run with cowling off.---Squirt some extra oil into carburetor.----May help pinpoint a leak.
Apr 25, 2026
J
JasonB
Side note, I did put a new impeller in it before running it. Possible I left something out?
Apr 25, 2026
Merc 250 Verado Fuel increase
Don't know which model VV it is, but can remove to get model number off back tomorrow if needed. Voltage readings at Bats with Bat...
Apr 25, 2026
P
Pmt133
18ft Boat Launch with RWD Suburban
Meanwhile half the roads flood from the bay you need to drive down on a regular basis.... yeah the salt air coast vehicles are some of...
Apr 25, 2026
dingbat
Working in the coating industry, I have a bit of insight on the subject. The corrosion rate of carbon steel in saltwater increases...
Apr 25, 2026
M
MikeSchinlaub
Question on cap removal
Remove the rub rail, make sure nothing inside is an attachment point between cap and floor, get three or four beam frames above to lift...
Apr 25, 2026
T
tphoyt
Trail camera issues fixed, now pics from them ...
Some of the hot spots are private lands but hunting is permitted with the land owners permission. The survey started right after the...
Apr 25, 2026
FLATHEAD
That is a ton of deer in some spots! 😮 Are they allowing hunting in those areas with such a concentration of deer?
Apr 25, 2026
2008 Glastron GXL 235, new 5.7 Mercruiser engine, bogging at 3000rpms
Good deal, and thanks for the update As the original thread starter you can post to the thread no mater how old it is.
Apr 25, 2026
M
muc
I'm not sure you have a battery problem. Here is something I found in one of DTS service manuals. Additional Horn Denial: A double...
Apr 25, 2026
J
JasonB
posted the thread
in
Johnson & Evinrude Outboards
Tinkering with an 82 7.5hp. I have it running great, but getting a lot of smoke coming out from under the engine pan and some under the...
Apr 25, 2026
flashback
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
No there are (will be) spacers that are thicker than the nuts . . . The transoms of the boat & extension bracket do not come in...
Apr 25, 2026
aspeck
That is a heavy concentration of deer steaks!
Apr 25, 2026
Fun Times
Mercruiser 5.7L and 5.0L, help me identify a part
Gotcha, all the original accessory parts came off of the original 5.0 and went onto the new 5.7l engine block. If possible, try to...
Apr 25, 2026
